Here ya go.. apologies for experimental messiness.
Clock on left, DAC on right. Zoom in to see the stacked pieces of fo.Q on BNCs/cable connnectors. In hindsight I wish if cut em consistently slightly larger. Ah well. There's no adhesive between the fo.Q blocks, they fall off with a light touch, annoying. Will come up with a better longer term solution... apply some spray tack and/or tape em on.
LHY SW-8 clock with 6 BNC outputs:
- 2 grounding cables to ground box, QA silver coated copper, CDA's OCC 14GA X 2
- 3 X foil tapes to grounding box, the bottom one hides the clock cable, an Harmonic Tech DC III, foil wrapped over the exterior ground of the BNC plug and socket. (Peg is to hold foil on firmly, actually sounds better) I find the foil is audibly complementary to wire ground cables.
R26 DAC (top to bottom, cables with fo.Q)
- ethernet cable
- s/pdif coax input - QA silver coated ground cable (I need to buy some more OCC 14GA)
- 10Mhz clock BNC input (HT DC III cable as above, should probably ground this end too per CDA advice...)
