DIY Earbuds
- Thread starter gwompki
Guys what are keywords to find MMCX parts for earbud? My search returns mostly Bluetooth parts in aliexpress.
DBaldock9
Try searching for "mmcx socket".
Thanks. I use "MMCX female" and found bunch too .Try searching for "mmcx socket".
If it can help, here is the link of the MMCX PINs I always buy from ali (good seller and nice package, I recommend).Guys what are keywords to find MMCX parts for earbud? My search returns mostly Bluetooth parts in aliexpress.
A bit expensive but didn't found cheaper for now for 10 pairs (at this exact dimensions). Excellent quality, and all my units are working perfectly for now
Thanks. I might try to get 2 pair. One for earbud and one to fix my xe800 iem.If it can help, here is the link of the MMCX PINs I always buy from ali (good seller and nice package, I recommend).
Edit * maybe 3 pair, my piston also in dire need of repair (if I can find a way to open it.)
Edit 2
Those 150 ohm, is there any reference (to common earbud) in how they sound? Seems interesting
Just bought some drivers. So I got a couple of drivers. I am confused which lead is + and which lead is - on both of these can someone give me a pointer?
https://www.aliexpress.com/item/ori...204.html?spm=a2g0s.9042311.0.0.65294c4drDBEQC
https://www.aliexpress.com/item/MMX...83.html?spm=a2g0s.12269583.0.0.52013904iRFVhv
thanks
thanks
With the driver connections nearest you, + is on the left
Merlin-PT
- Jan 21, 2005
@spikyfugu
In each driver, you need to find a mark that identifies the side with the same polarity solder connector.
For example, in each of the 600ohm drivers (see photos), there is a RED dot that identifies the same polarity solder point side.
In the 150ohm drivers (see photos), the same polarity side is marked with a BLACK line (and some color painted in that side metal).
@Merlin-PT
So for 600ohm one, the red dot side means the polarity (+) side and the opposite side is ground (-)?
And for 150ohm one, the black line side is polarity (+) and the opposite side is ground (-)?
Merlin-PT
- Jan 21, 2005
Yes, I use the color mark in the drivers as the positive and no mark as ground.
Thanks for the pointer
