DIY Earbuds
48 49 50 51 52 53 54 55 56 57
59 60 61
  1. Merlin-PT
    rahmish, DBaldock9, endia and 2 others like this.
  2. JackFlash
    Shorter looks great.
    Merlin-PT and DBaldock9 like this.
  3. HungryPanda
    My latest creation with mmcx connectors. 32 ohm carbon drivers
    rahmish, Merlin-PT and DBaldock9 like this.
  4. DBaldock9
    @HungryPanda - Have you tried this $18.50 back shell, from Chitty's Store?
    [​IMG]
    cathee and HungryPanda like this.
  5. HungryPanda
  6. DBaldock9
    I've found out that the silicone insulated wire that I used for those earbuds, can't take the stress of being used by active boys.
    Where the wires come out of the connector & heat shrink - the copper wires broke, inside the flexible insulation.
    I've replaced the earbuds - using pre-assembled cables from AliExpress (which include Mic/Remote phone controls), these drivers [ https://www.aliexpress.com/item/DIY...headphone-speaker-Heavy-bass/32325458276.html ], and some more of the modified MX500 shells.
    HungryPanda likes this.
  7. viatraco
    Is PK1 red film driver is better than transparent ? Isn't it too bass muddy ?
  8. spikyfugu
    I just built a custom one with pk1 red film. Sounds great and crisp for mids and highs. Sound stage is also quite good. Bass is a bit on the weak side when not EQ but I was playing around with PowerAmp and my LG G7 with QuadDac Hifi on with 50% more bass on EQ and it came alive. Maybe I need to somehow tune the bass on the shell.
    viatraco likes this.
  9. DBaldock9
  10. HungryPanda
    I tried David but ended up not using them, treble is piercing with very little bass
  11. HungryPanda
    My latest little creation, I got the earbuds for £0.90 but there was no left channel. The problem was with the cable but desoldering the cheap drivers destroyed them. I recabled the shells and used some 32 ohm "sweet vocal" drivers I had. Now they sound rather good.
    DBaldock9 likes this.
  12. DBaldock9
    That's a really tiny looking shell.
    I wonder whether a "Subwoofer" driver would be able to generate some usable low Bass?
  13. HungryPanda
    I'm getting great bass from these
  14. Jsingh4
    Guys According to you which are the best 14.8mm and 15.4mm drivers available.
  15. HungryPanda
    Depends what sound you want. 14.8mm pk1 or pk2 are best. 15.4 mm I have used so many different ones
59 60 61
