Based on your comments, we can see that you are an expert in this, but you are too modest to admit itWhile I'm not an authority on the exact proper techniques, this is what works well for me
DIY Earbuds
- Thread starter gwompki
rprodrigues
Has anyone here already modded the stock cable of TP16 to balanced?
The same question to Tomahawk.
I can't figure out, by external inspection, if its stock cable has 3 or 4 cores...
In most cases stock cable has 4 cores: one wire for left (L+) and one wire for right (R+) channel and 2 wires for ground (2 x G).Has anyone here already modded the stock cable of TP16 to balanced?
In the case of (2.5mm plug) balanced cable 2 wires for ground are L- and R-.
Another is 4.4mm plug PENTACONN
Use a multimeter to determine which pinouts on the inside (where soldering is performed) match the outside.
Also, this is useful info "Pinouts for DIY"
cappuchino
Previously known as sub30
Need HEELLPPP
Just finished recabling my earbuds. Only the right earbud works. What do I do? THere's like oxidation in the driver of the left one. Did I f'ed up?
captione
Can you take a picture?Need HEELLPPP
cappuchino
Sorry... can't at the moment. Tried everything. I think I overheated the driver or diaphragm or whatever part breaks when too much heat is applied. Good thing that it was on my Vidos, though I broke a perfectly working pair of buds which I really enjoyed.
"Welcome to the club" Now will know what can cause problems next time.Sorry... can't at the moment. Tried everything. I think I overheated the driver or diaphragm or whatever part breaks when too much heat is applied. Good thing that it was on my Vidos, though I broke a perfectly working pair of buds which I really enjoyed.
A great experience is gained with such mistakes, so "don't worry be happy".
At least you tried with a cheap pair. Modding is a risky business, but that is the charm.
If it's any consolation, every time I make a bad move , I take a short break and watch a motivational video,
something like this one.
I am currently planning to take some used pair of Grado SR80e and try to mod it.
This model is perfect for experimentation
Themilkman46290
I have got the sr80e, great pair, I haven't modded mine, but once I have the proper tools, I plan on making some cups...
Probably because you're happy with how the original soundsI have got the sr80e, great pair, I haven't modded mine, but once I have the proper tools, I plan on making some cups...
There is a lot of things that can be so fun to do:
- Cups (aluminum or wood) - they suggested that the cup need to be shorter with a sparse mesh
- MMCX will be a nice addition
- Headband with more padding etc.
Also, the 2K peak will be difficult to solve.
Apart from separating the glued parts, this would probably be the most demanding task.
The other pair I'm also interested in, even more than Grado, is Sennheiser HD25 Light.
It's a cheaper version of HD25, same driver, with a simpler headband and 2-side cable which is ideal for a balanced version.
The most important thing is that it can be easily disassembled (no glued parts) and there are many aftermarket mods for it.
Customcans are very good but LOCENOISE is another level for sure
Themilkman46290
Yeah, they do sound pretty good, my idea is to make wood cups, and transfer drivers, then experiment with the earpads and meshes, but for now, have to keep doing the home renovations ( no more gear until all the furniture and living room is done!!) but I am lucky, my wife is a bit of a hifi addict so it may happen sooner.............Probably because you're happy with how the original sounds
You are really lucky manI am lucky, my wife is a bit of a hifi addict so it may happen sooner.............
I hope you've seen this one before. It's like "Rolls-Royce" mod for Grado
Themilkman46290
Haven't seen this video, but thats pretty much what I would like to do, leather head band, alloy gymbals and wood cups.......
Allready have the purple heart and wavy maple wood, and some really nice, 2.2mm thick un dyed veg tan Italian leather....
Sam L
Nice! Regardless of whether you achieved your target 100%, I absolutely LOVE the thinking and spirit of innovation behind the effort. Just made my day by viewing this post. I'm really interested in what future efforts look like!
On the left you can see inside of the original shell. This cascading profile muffles the sound. On the right is modded shell. I used file tool to trim this "staircase" shape but
but I didn't get much open sound. It's not worth it
This is a very good comment (at 47:20 min) by Paul on why the size and shape of the inside of the shell are importantNice! Regardless of whether you achieved your target 100%, I absolutely LOVE the thinking and spirit of innovation behind the effort. Just made my day by viewing this post. I'm really interested in what future efforts look like!
Merlin-PT
- Jan 21, 2005
This 11.11 there's a good price (77% off) for these smabat drivers:
https://www.aliexpress.com/item/4001268432243.html
Total: 20 (members: 0, guests: 20)
