It sounds like you prefer a lean, flat/smooth sound signature. Have you tried removing the white cover from the speakers? I almost always remove any cover from new speakers for similar reason that you brought up - it usually creates harsh upper mids, boomy bass, makes the tuning process harder.Took them off burn-in after 100 or so hours, there wasn't as much change as I'd like. Still a warm, punchy signature. The mid-bass still sounds a bit boomy or intrusive with foams on (I used offset donut foams).
Because of that, I pulled the foams off and the boominess disappears, mid-bass punch is tamed and the mids/highs are now presented in a more forward fashion. Upper mids/lower treble almost becomes fatiguing and is borderline too much for me (can easily be fixed with EQ, but for the sake of giving impressions I listened without EQ). Definitely a driver to use without foams IMO.
When it comes to IEM's I prefer a sound sig that is somewhat harman like, but with 1-3db less upper mids/lower treble and a bit less bass by 2-3 db that tapers into the lower mids a bit smoother (ie: my mh755/mh750 I pull about -3db at 31/62 hz and -1.5 db around 125hz via eq).
That being said with no foams the bass is still decent in quantity until it reaches into the sub-bass (50-60hz and below), these drivers start picking up around 30-33hz when I did a sweep and the bass is fairly level from 35h40hz up. In other words bass rolls off around 30-33hz.
Bass/mid-bass and lower mids are good but the upper mids/lower treble is a bit harsh if I turn the volume up above my average listening volume (low for most). So if I was in a somewhat noisy place, out and about or when driving/commuting it may be fatiguing/too harsh. When sitting at home or in a quiet environment they are ok.
I personally could never again use an earbud without foam. I used them like that throughout my teen and I've had enough of harsh thin sound + hard plastic in my ears haha.
I prefer a sound signature that evokes a large set of speakers, so deep impactful bass, natural and smooth midrange, airy treble. I'm experimenting with methods of side-by-side comparison of earbuds and speakers for tuning purposes. I'll share the process in the close future.
Question for everybody: How do you evaluate your tunings? Do you have some kind of a reference gear or benchmark that you use? How do you assess sound signature? It can get quite subjective, especially when comparing different kind of audio gears. I mean, sometimes a so-called V-shaped earbud can sound much flatter than a trendy closed headphone. Sometimes a so-called flat earbud can sound anemic and dull compared to even a small bookshelf speaker. How do you navigate between the relative (compare only to earbuds) and the absolute (compare between other types of audio reproduction). I guess it also depends on the individual ear + shell synergy. For example, I have some shells that go very deep and tight into my ears, which magnifies the feeling of pressure and harshness, so with these shells I prefer a less obtrusive signature. While with other shells that have a more relaxed fit, I can get braver and tune the sound to be more exciting.
