Finally taking some time to listen to these after burn-in. A very similar sound signature to my legit O.G. yuin PK2 drivers, with better bass and sub-bass (both quantity and extension). So I'd call these a warm, non-fatiguing, almost smooth sound signature with no sibilance or harshness.
A quick listen to a frequency sweep (20hz up) and these do make sub-bass at 20hz but it is somewhat rolled off and starts in the mid 30hz range. At least it is there.
I'd cut or crack the shell with small wire cutters on the opposite side of where the voice coil wires are. Then see if I could peel the shell back with some small pliers to 'release' the driver. IMO it is best to work away from the thin and delicate voice coil wires whenever possible.
Similar to how my diy 150Ω red film drivers cracked trying to fit them to a slightly too large shell. I peeled or bent the cover a bit and the driver fell out at this point.
