DIY Cable Questions and Comments Thread
post-15622185
Post #9,692 of 9,752
dontfeedphils
W MI
W MI
Dang, Thanks for the confirmation, first time doing this and I got it wrong the first time.
FYI, a decent DMM can be had for quite cheap and makes it easy to verify these sort of things.
Reactions: 3ggerhappy
post-15622194
Post #9,693 of 9,752
3ggerhappy
Yeah, ordered one actually but its taking its time to arrive due to the covid situation. Also do not know how to properly use it still(except maybe basic continuity feature) I'll go experiment when it arrives.
Reactions: dontfeedphils
post-15622384
Post #9,694 of 9,752
doctorjuggles
London, UK
London, UK
Until it arrives, it's worth sharing that every standard connector I've used so far (2.5mm/3.5mm/4.4mm) has always worked back to front - so the tip of the connector is usually the smallest part of the soldering end (and the furthest away from the tip) and works its way back. Make sense? If not I'll try and draw a rough diagram for what I mean
post-15622418
Post #9,695 of 9,752
3ggerhappy
Makes sense :beerchug:
post-15623020
Post #9,696 of 9,752
doctorjuggles
London, UK
London, UK
The multimeter makes building things much easier though. I used to fret about which wires were which and drew on them or wrapped coloured thread - now I just solder and braid and then worry about which one is which at the end (or at least once it’s time to do the split)
post-15624317
Post #9,697 of 9,752
shrimants
so this is probably a real dumb question. I did look through all the gallery images to see if I could make this out from someone's pic but no luck. The eidolic connectors I have (2.5mm TRRS and 3.5mm TRS) seem to just be hollow barrels on the "wire" side. What do you guys do to plug that hole up? They came with some rubber plug looking things but they dont really fit all that great.
Do you just melt hot glue into there? or some form of epoxy? Or is there some specific way to use heat shrink tubing?
Same question goes for the cable splitter, its a hollow tube with one end wide open and the other end having a 2-hole sort of design, which I assume is for splitting the wire off between left/right sides.
how do you guys provide strain relief? or is the glue/heat shink enough to strain relief?
Still hoping someone in this thread has used the eidolic connectors.
post-15624325
Post #9,698 of 9,752
dontfeedphils
W MI
W MI
I use Eidolic connectors and just used some heatshrink over the connections inside the connector and left it long enough that it protrudes from inside the connector a bit for strain relief.
post-15624596
Post #9,699 of 9,752
shrimants
no glue/epoxy inside the connector?
post-15624599
Post #9,700 of 9,752
dontfeedphils
W MI
W MI
Naw, I don't really see much of a reason. I suppose it may depend on the wire you're using though. If it's flimsy and a small gauge then maybe, otherwise a solid solder joint and heat shrink should be just fine.
post-15625691
Post #9,701 of 9,752
qsk78
Russia
Russia
Hello. I plan to make XLR interconnect cables based on Viablue NF-S1 which has two shields.
While the XLR connector has just one pin for the shield. Should I twist both shields of the cable together and solder them to 1 pin? Should I use only the outer shield of the cable?
Thank you.
post-15626119
Post #9,702 of 9,752
Speedskater
If both shields are braids, you could:
a] use one
b] use both
c] connect the inner at both ends, and the outer at the send end (if the unit is powered), for a mic do the opposite.
If one shield is braid and the other is foil or spiral:
a] use the braid
If both shields are spiral
a] use both shields
Reactions: qsk78
post-15626129
Post #9,703 of 9,752
qsk78
Russia
Russia
Thank you. This is how actually it looks like
Four shields "Quattro Silver“
  • •2 silvered spiral shields
  • •2 ALU-PET foil shields
post-15626252
Post #9,704 of 9,752
Speedskater
Lets get creative!
So if the foils have drain wires:
Both spirals at both ends
one foil at one end
the other foil at the other end
But at the end of the day, in the residential real world, it won't make any difference which way you connect them in an XLR balanced interconnect.
(balanced XLR interconnects are much more robust [noise & interference wise] than unbalanced RCA interconnects)
Reactions: qsk78
post-15630511
Post #9,705 of 9,752
Sunstealer
UK
UK
Well it's taken a while and lots of mistakes and practice cables but have finally made one I like:
Thanks to @Saturnian, Cosmic Cables for the wire: 6N copper and 6N SPC. 4.4mm from CEMA. I don't mind the red heat shrink but will probably use clear in future. I tried those 6mm rubber jack plugs but it was a tight fit. Any other suggestions?
I use threaded connectors so I can change from 2 pin to MMCX when I'm testing new IEMs.
I have some 4N silver cable from CEMA so will get started on that soon. Also made a 4W 7N copper cable that looks great.
Users Who Are Viewing This Thread (Users: 2, Guests: 2)
