scootermafia
MOT: Double Helix Cables
- Nov 24, 2008
Looks cool!
I've got a problem guys, I bought this Hicon jack but it seems to be wired differently internally and I don't know where the contact for the tip and for the ring is.
For reference:
I know where to solder the negative wires but I'm having trouble with where to solder the left+ and right+ conductors.
You could always measure it with a multimeter.
I would guess that the right positive goes to the crimpy clip, Left positive goes to the thingy around that pin in the middle, and the negative (ground) goes to the pin in the middle.
I may have guessed wrong on purpose to encourage you to measure it for yourself.
Please Recommend me a 4 PCS.10mm RCA Plug(male) for not more than $20.00.THANKS!
It's solid core, and 28 gauge is tiny, which means your cable will be stiff, fragile, and have a pretty high resistance.
Why do you want such expensive cable with so many downsides and no upsides? You'd be much better suited with 20-24 gauge stranded wire with a PVC jacket, then throw that in some paracord and you've got yourself a nice cable. If you're worried about oxidation (not a problem with a good wire) then you can find tinned wire which usually has a lead free solder tinning.
I highly recommend Cooner wire, but their prices are usually pretty high and require a large order to be economical. Pulling wire out of Canare or Mogami audio cables is a good way to go, though PE insulation is going to be a bit stiffer, workable though.
Neutrik plugs. You can find them at Redco.com
