DIY Cable Questions and Comments Thread
post-15471247
Post #9,556 of 9,726
furyossa
Serbia
Serbia
I am interesting to make two balanced custom cables for my Samson QH4 amp which use balanced 1/4” (6.35mm) TRS left and right inputs
The first cable (2.5mm balanced TRRS to dual 6.35mm TRS) would be to connect iBasso DC01 (2.5mm TRRS output) with Samson QH4 (dual 6.35mm TRS inputs)
Second cable (4.4mm pentaconn TRRRS to dual 6.35mm TRS) is for iFi Zen DAC (4.4mm TRRRS output) and Samson QH4 (dual 6.35mm TRS inputs)
I put together this little booklet in attachment with some information for these devices and schemes for these two cables (version #1 not use ground and version #2 with ground included). My question is: if this is the correct way to wire these cables, and if so, which of these cables should use ground and which not?
I would really appreciate any advice
Reactions: rprodrigues
post-15475627
Post #9,557 of 9,726
imas69
I think you should be using 8 strands of wire as per your diagram but with 4 strand going to each 6.35mm from the 2.5mm trrs and the 4.4mm
Reactions: furyossa
post-15475634
Post #9,559 of 9,726
imas69
Looking for a good quality 3 pin xlr (male) I have tried cosmic cables but they don't seem to stock them, does anyone have any other suggestions in the UK
please.
post-15475762
Post #9,560 of 9,726
furyossa
Serbia
Serbia
Yup. For 2.5mm to dual 6.35mm, I need a minimum of 6 strand ie 4 strands for signal (R+, R-, L+, L-) and 2 for: (L- to left ground and R- to right ground.)
Same as for 4.4mm but last 2 strands go: pentaconn ground to left ground of 6.35mm plug and one for right side
Both cables should have R- and L- going to ground at the 6.35mm
So you suggest version #2 from the booklet? Did I choose the correct wire direction?
post-15485802
Post #9,561 of 9,726
vanerik23
Philippines
Philippines
Hi guys! I'm very new to this forum. In fact, this is my first post!
Have any of you guys worked with this type of cable?
I'm just wondering how to properly strip these cables. I've worked with other types of cables before but all you need is a wire stripper for that. This one does not seem to like those though. Any ideas? Thanks!
post-15486854
Post #9,562 of 9,726
imas69
Try burning it for a second with a lighter and then pulling it off with your fingers but you didn't hear that from me.
post-15492704
Post #9,563 of 9,726
vanerik23
Philippines
Philippines
I've tried that but I usually end up with soot on the wires and that makes it hard to tin. Any tips on how to avoid that?
post-15492743
Post #9,564 of 9,726
Saturnian
Member of the Trade: Cosmic Cables
London
London
Are you sure it's not litz wire and that you need a solder pot, see if you can get a signal from end to end with a multimeter, if not then you probably need
to remove the enamel
Reactions: imas69
post-15496117
Post #9,565 of 9,726
chrisdrop
London, United Kingdom
Hey all. What is different between a SPDIF coax and an RCA cable from a DIY perspective? I have made a few pairs of interconnects, just wondering what is needed/ different.
A different gauge of cable? Different RCA connectors? Any parts/ cable recommendations?
post-15498436
Post #9,566 of 9,726
vanerik23
Philippines
Philippines
I don't think there's enamel on the conductors. I think each conductor is sealed with some silicone and cotton. Of course I could manually separate the fibers but that's going to take forever. here's a link to the item on aliexpress: https://www.aliexpress.com/item/328...earchweb0_0,searchweb201602_,searchweb201603_
It's actually silver foil wrapped around something and serves as 1 strand. There are 7 strands per share.I think there's cotton fibers in-between each strand. This seems pretty complicated that's why I need a little help. I'm able to make custom cables for my headphones with this but it takes so much time to get the ends ready to be tinned and soldered on to connectors. There must be an easier way.
post-15500112
Post #9,568 of 9,726
imas69
Reactions: Saturnian
post-15500677
Post #9,570 of 9,726
Darksoul
Colombia
Colombia
Recently I've gotten the itch to try different cables, for "science." I want to listen my self. Perusing, my experiment would cost me upwards of 500 USD, that's just nuts. However, I saw that if I buy the cables and connectors my self, everything could go for 150 USD, if I buy all the types of cables I want to try. Much more reasonable.
Maybe this was already answered here, you'll forgive for not being more diligent with the use of the search function. But I would like to know these things:
1. Why do I need a solder pot to solder Litz UP-OCC cables?
2. What sort of solder I need to solder silver plated cables?
3. What sort of solder I need to solder 100% silver cables?
4. Do I need to buy special connectors to use 100% silver cables?
Thank you in advance.
