Paladin79
Previously MOT: Cables For Less
Nicely done as well. I do have some very tiny mesh that I want to try to use inside the hd 800 connectors. Solid silver wire should fit nicely and when done, it is not larger than 24 awg insulated, or at least that is my intent. Using heatshrink tubing inside those connectors is pretty difficult and if it is close to where you are soldering, you run the risk of inopportune shrinking.
