Albator75000
OK, I'm going to research on this.
Thank you.
I'll come back if need be
Thank you.
It does double the output which I need to do in order to drive some of my headphones. It doubles the milliamperes, One amp times a nominal 100 volts equals 100 watts and thus too much for most headphones. I have seen some cans rated at a maximum of 5-7 watts. Put more than that into them and the little wires that normally carry a signal start acting like little fuses if you are lucky. Think of the warnings about staring at the eclipse without proper glasses only substitute ears and loud sound for eyes and the sun.I believe the balanced output of the liquid carbon use twice as many amps as the SE output, so you should get significantly more power to the headphones.
I could use some specific information on Connector and Cable sizes.
I'm planing to do a new cable for my HD600. The connectors for the cups seem to only be available from china (if anyone has a source in Europe, i'd be really glad). They are only 4 bucks a pair, so i'll order 3 or 4 From Ebay.
I'm planing to do 2 Cables. One for desktop use one for mobile.
The base will be earcups to 4pin tinyXLR. From there i'll do two cables. One to 6,3 and one to 3.5. Both significantly shorter than stock.
What infos i need:
- which is the maximum outer diameter cable i can use in the earcups connectors (assuming two singel conductor cables)?
- What size heatshrink fits over the Sennheiser connectors?
- What's the maximum size cable you'd get for tinyxlr-6,3mm assuming i use 3 single conductors?
In the past i've had the Problem of not getting the cables into the connector because of size. This time i'd like to make sure it works before ordering a bunch of stuff...
Also, if you can recommend any specific cable/materials i'd be happy to look into it. Otherwise it'll be mogami (not sure what i can get yet).
Did you use the whole cable or just the inner conductors? I did cable with just the 4 conductors without the jacket and it is more pliable than w2893 with the jacketI'm planning to build a balanced custom headphone cable for Hifiman HE-400i. I've build the balanced custom cable for Senn HD600 using Canare L-4E6S Star-Quad cable, but it's too bulky, stiff and heavy. Can anyone recommend me a good cable I can use?
