Letmebefrank
- Apr 18, 2015
Huh, negative is ground.
Positive and negative in transducers are for phasing, you don't connect the output of an amplifier to earth or you will ruin it.
Thanks, I am use to using star quad for balanced mic cables. But we always tie two of the conductors together, it thought it was designed for that.Single entry headphones share a common ground, and the cable can certainly be two conductors and a shield with drain wire, thus the shield is ground. Fostex and lower end Beyerdynamic use this.
Twisted pair is a form of shielding as is a physical shield. Some of the better cables use one twisted pair and a shield or even a double shield, those cables are not very flexible. Star quad is often used with dual entry headphones and there is a spiral twist, the shield should not be used as ground IMHO since two separate grounds already exist and an additional ground would form a loop and act like an antenna.
Ground isn't earth.Positive and negative in transducers are for phasing, you don't connect the output of an amplifier to earth or you will ruin it.
Such cable can be terminated depending on usage, BNC connectors, F connectors or most likely RCA connectors. For audio use and digital audio go with RCA connectors. My people use Canare connectors but the tools can be pretty pricey so your best bet is to use Neutrik/Rean connectors. There are two conductors in such coaxial cable, center conductor and braided shield. Attach shield to ground and center conductor to center post of the RCA connector. Here are some that would work well. These are solder type connectors.
http://www.tecnec.com/Product.asp?c...&baseitem=NF2CB-2&search=0&off=0&showreturn=0
http://www.tecnec.com/Product.asp?c...aseitem=NYS373-BK&search=0&off=0&showreturn=0
I also like these Amphenol RCA connectors
https://www.alliedelec.com/amphenol-audio-acpr-red/70400416/
You can use the 1694A for audio interconnects, Subwoofer cables, Digital audio cables (SPDIF), HD/SDI and video but your easiest use would be audio interconnects, but just remember down the road that cable is capable of other usages if you so desire. It will do low frequencies but has been sweep tested up to 4.5 gigahertz. The engineering staff at a local university use that series cable mini rg 59, RG 59, and RG 6 (the 1694A) for most any coaxial cable usage and I have built 500 foot cables with it that were used for filming such things as the X games.
Tom
