Question about wiring, i got the sommer cable peacock for my hd800.
I plan to wire it for balanced, and use an adapter for unbalanced amp.
if i got this correct, i would wire the shield of each cable to the ground tab on the xlr, wire the red/white cable to + and -, and on the headphone side only wire the + and -, and not solder the shield?
then for the trs jack adapter (would use same cable), i would wire the shield on the xlr female side, but don't wire it on the trs jack? attach left and right minus to sleeve of the trs jack.
talking about this cable: https://www.rapidonline.com/sommer-cable-sc-peacock-mkii-speaker-cable-549508
i'm using neutrik jacks for everything else (XLR male, XLR female, TRS male)
I would not connect the shield at all on any of the connectors.
If you think you must, due to high EMI, then only connect the shield to the ground/shield tab on the male XLR, then connect the shield to both the female XLR's ground/shield tab, as well as the shield of the 1/4 plug of the short adapter cable you are making.
The idea is for the shield to act as an antenna for any EMI, and for any such current to "drain" into the ground (earth) of the device you are plugging into. If you don't connect the shield to the ground/shield tab on the female XLR connector, there will be no way for the EMI to drain from the main cable, through the adapter.
But really, if you snip the shield on both sides and just worry about conductor wire, you will be fine.
