Ah yes, I guess I should explain more. Sorry about that.
I am using this with a desktop amp that is designed for headphones. My friend, the one who made it guaranteed that it should be enough to drive my speakers(albeit up to a certain level), because he had tried before with his speaker sets.
So I need the TRS connector to solder all the 4 ends(2 for each side) in the configuration similar to headphones do, which is L, R , Ground(for both sides). This TRS jack will then be connected to the amp out, which the place where my usual headphones go to. The other out the amp has is the DAC out, so not gonna use that.
I don't have a speaker amp atm, but will probably buy if this amp of mine can't drive the speakers well. Hope this clears everything up. Too tired to think straight now lol. Will continue tomorrow.
Yes it didn't make sense at first that clears it up. The tip is for L+ the ring is for R+ and the to negatives go to the sleeve and you should be fine if the speaker cable will fit inside the barrel. If it for temporary use why not give it a shot.
