drambit
- Jan 29, 2015
Epoxy to what though is the question. I have a soldered connection, I have epoxy, I have nothing to put brace the wires to with epoxy to redistribute force.
Post a picture. It'll make it easier to see where you're at currently.
One more question, is it really hard to fully recable a M50?
Also does this techflex at 1/16" work for individually sleeving starquad? I like a tight look. Paracord at 2mm is a pain in my ass
http://www.ebay.com.au/itm/3m-Length-Black-Techflex-Flexo-PET-Expandable-Braided-Cable-Sleeving-/230927952950?pt=LH_DefaultDomain_15&var=&hash=item35c460ec36
http://i.imgur.com/uMJRar3.jpg
Two wires to the left cup two wires to the right cup and the full size cable to the jack. I'm going to solder them together but If I do that without any way to brace them the junction will tear apart.
PS: Is there a braiding guide around here somewhere? I used a drill to twist the wires into a vice, but it is a ****ty braid.
Solder is pretty darn solid if you make a good joint. Is there some reason significant force will be applied to the cable? That seems like the real issue.
Anyway, you join the wires by twisting them together and soldering. Cover each joint with a small piece heatshrink. Use some Epoxy putty on the whole area. You can shape it how you like with the putty kind. Let it cure, then cover that with an adhesive heatshrink.
If someone manages to pull that apart, then they are doing something horribly wrong to the cable.
I'm trying to think of a way to do it without adhesive heatshrink because I'm being paid $20 to do this, I'm already using like $9 in supplies, and I've put like 4 hours into getting them going, so it's not even remotely worth it as it is, and the cheapest heatshrink is about $5 which is just excessive. I think maybe if I just epoxy the area and use regular heatshrink it will be fine but idk. Also the reason I'm concerned about force distro is not because there that likely to be someone pulling it apart but just because it's stupid design to make it in a way so that if you were to tug on it the force would go to the solder joints, the force should always be going to the sections of cable on either end of the solder joints. Next time I do this I'm going to make sure I do it the right way lol.
Please, I just got my se215 iems and I definitely need new cables, the stock is super sticky and I don't like it really...
I didn't find about making iems cable, I just see about full sized cans cables...
Can someone guide me in the right direction :/
You can pick up the the MMCX connectors fairly cheap from Norne audio if you don't want to wait for shipping from China.
As far as wire goes, you can either pick up a prefab cable without termination from somewhere like Lunashops or Ebay.
Alternatively, you can find some really light/thin litz copper that fits the bill pretty well from here
Another option is to just use something that is flexible with soft insulation. I highly recommend Plussound audio's 28awg SPC. I made a cable for my JVC FX850 and it's fantastic.
It's my go-to wire when I want something that checks all my boxes and has a nice, soft feel.
Finally, you could just buy a stock cable from another IEM. I personally like the stock JVC FX850 cable. I think it's pretty screwing fantastic. Lots of other premade mmcx cables out there. Aliexpress, Lunashops, Ebay, etc all have plenty of options.
It all really comes down to your personal preferences and what you're exact wants/needs are.
i've been testing a cable made from the silk wrapped litz from that site on one of my grados for a couple weeks
its holding up well no silk coming off, it may fit the bill quite well its very flexible and soft to the touch
