DutchGFX
- Dec 1, 2012
Redco is in Stratford, CT I think, its like 2 hours from me
I wish to build my own self a Christmas present for once. Just want to know if this cable will do the trick for my AKG K702/65? http://www.ebay.com/itm/271650851723
My plan:
Cutting them into 7 line of equal length. 2 for left channel, 2 for right channel and 3 for the ground wire.
Q: Should I just make it one for all? Will it make a difference?
Using nice cable sleeve to sleeve the 3 up separately [left, right, ground respectively].
Will this work?
Thanks
Billson
Well, you can use as such as its teflon coated and sleeve/sheath the wire.......and yes you can use 2 strands each for positive of both R and L and 3 strands for common ground.....you just need to mark them which goes where and check them correctly before and after soldering using a DMM or analog.....imo.
So I can immediately build a cable for my headphone without trouble using just that cable? Sleeving is optional in this case now right? Thanks!
The sheath/sleeve is both for fancy looking and especially durabilty,tho its not a must and you can show off the transparent cable,shiny SP ofc cable w/o that........ its all personal preference.
And Billy, I wld say you wait for some of our fellower's inputs on the subject,who did the similar cabling already for theirs.......
Alright, many thanks!
Will do. But a tempted to order it now thought hahahaha. I want it done before Christmas lol
It's worth mentioning that AKG usually (always?) reverses the Left and Right channels on their pin-outs (pins 2 & 3). Before the DIY bug bit me, I had Redco make me a cable without knowing to tell them it was for an AKG (they might not have known), and sure enough, they were reversed. That cable became a pair of interconnects It's that way on the two AKGs I've checked (Q701s and K712s). For the cables I made, I used the following on the mini XLR, with a TRS plug on the amp end:
Pin 1 : Ground
Pin 2 : Ring/Right
Pin 3 : Tip/Left
Easiest enough to confirm with a DMM on your stock AKG cable.
If you're planning to solder all those wires into a mini XLR, I'd be curious to see some photos before you close it up.
Good luck
It's worth mentioning that AKG usually (always?) reverses the Left and Right channels on their pin-outs (pins 2 & 3). Before the DIY bug bit me, I had Redco make me a cable without knowing to tell them it was for an AKG (they might not have known), and sure enough, they were reversed. That cable became a pair of interconnectsIt's that way on the two AKGs I've checked (Q701s and K712s). For the cables I made, I used the following on the mini XLR, with a TRS plug on the amp end:
Pin 1 : Ground
Pin 2 : Ring/Right
Pin 3 : Tip/Left
Good luck
Thx for the heads-up.....cld'nt all those wires fit inside the XLR shell/adapter?.....
Seems like it'd be a tight fit to me. I got four 100/46 type 2 Litz wires (served in silk, which is nominal) into my Redco mini XLR, but I don't think I'd like to try eight (was that the number) wires, esp. coated with Teflon or even the stuff Mogami uses in the Neglex. That's why I want pix of this hot-dog-eating-contest-of-a-cable-project. Video of the actual insertion would be even better
