RPGWiZaRD
- Jan 31, 2010
You got the ZO for the XB? Is the bass not enough?
No, if you read the review I got it for the technique they used in it, even using the flat setting that doesn't boost the bass the whole range is "boosted" by the same amount. Seeing how I liked boosting the whole curve on my hardware EQ and this looked like using similar technique I knew I had to get this as I'd call myself a "forward" sound enthusiast (ofc basshead as well) but the bass boost wasn't what I had in mind when getting this device as I could already get more than enough bass out of my hardware EQ. I had basicly already heard what kind of sound characteristic benefits this technique brings so I knew I'd like this ZO even before trying it. It's good to get it confirmed what I thought it would bring was correct though and further strengthen my points about this EQ technique I use that goes against typical audiophile beliefs is actually something that sounds great to me on a subjective level at least, the problem is that there exists almost no good enough EQs for this capability than what I use it seems but ZO does this as well, only you can't tune how much you can bring the whole range "forward".
