Originally Posted by SubseaTree /img/forum/go_quote.gif
there are subtle and non-subtle degradations of information such as timing, harmonics, dynamics, spacial clues, sins of omission and addition, etc etc that all effect
Timing - so some CD players run too fast or on some the drummer comes in too early
- transient rise time for DACs is about 23 microseconds -there may be some minor ringing on very brief signals but as I understand it this is at a very low level and really only affects very high frequencies. So far nobody has shown me that any differences in transient rise time between different DACs can be attributed to audible differences.
Harmonics - if a DAC really does add or drop
serious amounts of harmonics then that would be a serious issue, however when you look at DACs the level of harmonic distortion is generally very very low, i.e the output signal is very very close to the input signal i.e 0.01% harmonic distortion which is not as far as I know humanly detectable.
Dynamics - well DACs have dynamic ranges of well over 90db much much better than recorded music actually requires.
Sins of omission - this is the part I am having trouble with - what is missing exactly - this comes back to the waveform question how is the output waveform different from the original signal.
Sins of addition, noise and distortion - pretty much a non-issue with half-competent digital kit.
Spatial Cues - that is what stereo is all about - the differences between one channel and another create the illusion of solidity, as I understand it this is created by having , two similar but slightly different signals - each will have different time-of-arrival (phase difference) and sound-pressure-level information. During playback, the listener's brain uses those differences in timing and sound-level to triangulate the positions of the recorded objects. The DAC doesnt worry about this as it just processes a signal. The DAC just has to make sure that the two channels come out at the same time relative to the original recording - pretty trivial I would imagine.
If the designer has allow form to follow function and his ultimate goal is perfect sound reproduction, the chassis will be well damped, the componants will be generously spaced out to avoid emf induced distortion, the soldering will be faultless, the choice of componetary will show variety as if some thought has gone into selecting each cap. for the desired sound, it will perform slickly as this sets the listener in the right mood ... but for all of this it certainly will not be a sub $500 unit, unfortunately |
I guess you dont want me to give you the URL of the Spanish website which blind tested a 12,000 euro Oracle CD player and a 200 Euro Pioneer DVD player and found them to be sonically indistinguishable. Good design need not be that expensive, components that perform to spec need not cost a fortune, if a circuit works to spec it works to spec. Okay a 12,000 euro CD player may well last longer than a $60 Philips DVP642, mine has already lost its coax output.
