chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
Oh noo..its a crime to deprive one of his enjoyment of Zana..
Originally Posted by bordins /img/forum/go_quote.gif The 30-year-old Red Book Audio standard defines several things for capturing analog sounds into a digital form. However, the error correction scheme, that was considered quite good 30 years ago, has some limitation so that you may hear clicks or masked sounds some times. |
This implies you can always retrieve perfect bits at your CD player, nothing added to the original bits. Cheap univeral player today (with a large memory buffer and a fast processor) can be as good as $$$$ audio CD transports in the past, in this regard. |
The rest is to reproduce the original sounds from those bits, and this is no longer straight forward as you may think, You may know that different DAC chips produce different sounds. The chips have certain "signatures", similar to audio tubes. Components inside the player also affect the sonics. Accuphase CDPs sound warm while Rotel CDPs sound brighter. Lastly, There are all types of noise to be dealth with, like what bigshot mentioned above. |
I like an article at tnt-audio, What is Jitter ?. It explains why the same bits can sound different. You can find a lot of information there. PS CDM vs Player Make & Model List |
Originally Posted by hciman77 /img/forum/go_quote.gif If a DAC chip has a signature it is basically flawed - the chip has to reconstruct a waveform. |
Originally Posted by Freddi /img/forum/go_quote.gif Loving the info here! Although my wallet is less pleased ![]() |
Originally Posted by bordins /img/forum/go_quote.gif Thanks, hciman77 for the technical addition. ![]() Many have confirmed DAC chip signatures from a DAC that lets you swap DAC chips, like a Zhaolu. I own one and found AD-1852 and CS-4398 produce different sonics of the same music track. The AD-1852 makes music more airy while the CS-4398 makes a female voice more attractive, for example. It is why there are many DAC chips to choose in the market. They must differ, like 12AX7 v.s. 6DJ8 tubes, sound-wise. |
Originally Posted by hciman77 /img/forum/go_quote.gif Can you explain why two DAC chips that both perfectly reconstruct the same analog waveform can sound different. As long as two DAC chips are linear to 16 bits the analog signal ought to be the same. |
Originally Posted by hciman77 /img/forum/go_quote.gif From what I can tell the AD1852 is slightly better in the usual tech stats THD and so on but both are well pretty exemplary in real world terms. It is hard to see where any audible differences would come from. Cheers |
Originally Posted by bordins /img/forum/go_quote.gif Your assumption could be wrong. It is because the waveforms of different DAC chips are not the same. ![]() |
Originally Posted by Fitz /img/forum/go_quote.gif Which studies specifically? I'd like to learn more about this. |
