Mine have been working since the initial pairing mess. Fingers crossed. Glad I bought from Crutchfield just in case.
There is an openness to the soundstage in these these that I have not heard in a TWS before other than perhaps the Bose QC but the Gemini trounces them in overall sound quality. Most TWS feel very closed in by comparison.
Perhaps the battery can be replaced, but it does not look like it's meant for an end user to do. I removed all screws and found no easy access, especially around the wireless charging bits. Here's how it looks in there:
Hello, just received the Gemini and indeed the connection is a nightmare, I have no idea how to get it working well and connecting automatically to the phone when taking them out of the box... Sound is good but I was expecting better, I prefer the Sennheiser MTW 2.
Also received today the Noble Falcon pro and having both on the same day I must say I found the best TWS, the Falcon pro are something really amazing, I really like the way they sound and the way they handle the music, at least with fast music as progressive metal that I listen to most of the time.
I had really high expectations for the Gemini, but the fact that they are so bad in terms of connections makes them almost unusable. Let's see how this improves in the next days as I'm relying on experience for s short time.
The falcon pro looks interesting but those long stems are a non starter for me. I don't want to jam those in my ears. I prefer the length of the MTW2 and Gemini. I wish Noble had shortened them this time around. Anyway look forward to your impressions on sq.
It is easy to overlook, but note that both Bluetooth and location must be enabled in order to connect to the app.
Also the small button on the front of the charging case needs to be pressed to put them in the pairing mode the first time.
Good luck!
does anyone else have an issue getting Siri to work?
The double tap action seem to not work for me a lot of the time.
even answering/ending calls seem hot or miss, though I have a better success rate there.
