HiFlight
I haven't made or received any calls yet.Thanks for sharing, how's the call quality like?
To me, they do not sound like a TWS. Hopefully, other owners will chime in with their impressions and comparisons.wow better than andromeda that is a big statement for a tws
My first try failed but updated fine on second try. IIRC, I then removed and replaced them in the charging case, left the lid open and retried. Updated just fine this time.Did you successfully update the firmware? I get to a point where it's 99%, then a fail (transmission problem). I read that each bud updates separately, but I see no indication of that. I'm afraid I'm in the same boat as many other early adopters: tantalized by the sound but getting killed by the software.
Yes although after the update mine stopped doing that so far.Does anyone have an issue where one of the buds stays connected to the phone even after it's back in its case? Had that happen a couple of times already... Otherwise love these to bits.
Happened to me once or twice. I hope they can fix it via firmware.Does anyone have an issue where one of the buds stays connected to the phone even after it's back in its case? Had that happen a couple of times already... Otherwise love these to bits.
It happened to me post-update.Yes although after the update mine stopped doing that so far.
Will keep an eye out. Definitely not a well implemented bluetooth setup. Took me about 20 minutes to get them connected and I've been using tws for a long timeIt happened to me post-update.
This setup is brutal. I had to reset my phone's network settings as per this. Now at least my left updated! Right still fails but ay this point re-pairing (you can reset the device this way) will probably do the trick. Now I will refrain from making some off-color analogy about a temperamental, but irresistible, french mistress, but I'm definitely being pulled by my ears here!Did you successfully update the firmware? I get to a point where it's 99%, then a fail (transmission problem). I read that each bud updates separately, but I see no indication of that. I'm afraid I'm in the same boat as many other early adopters: tantalized by the sound but getting killed by the software.
Mine once showed empty for no apparent reason but plugging in to my charger filled the battery and this has never happened again. BTW, the battery is user replaceable. The ID number of the battery is listed in the documentation.This setup is brutal. I had to reset my phone's network settings as per this. Now at least my left updated! Right still fails but ay this point re-pairing (you can reset the device this way) will probably do the trick. Now I will refrain from making some off-color analogy about a temperamental, but irresistible, french mistress, but I'm definitely being pulled by my ears here!
edit: I spoke too soon! I now have updated buds, but the chamber has died. No LEDs and I can no longer pair. Listening to some awful hold music now.
No help from Devialet. It seems this is a common fail, will probably have to return <sigh>.
Yeah, it's not the battery, showing a full charge in the app. Definitely a firmware-stuck Chamber. There are instructions for getting it unstuck but it requires innumerable tries at 5 minute intervals. The instructions may as well have included prayer.Mine once showed empty for no apparent reason but plugging in to my charger filled the battery and this has never happened again. BTW, the battery is user replaceable. The ID number of the battery is listed in the documentation.
