alexlevn0791
guys, reading through the thread and just curious how does the Dethonray decode DSD and what is it ability to do it? Some of my fav albums just happen to be in DSD128 and 256. Thanks!
No plan for any DTR2 at the moment. Anson is now fully occupied with the upcoming USB DAC/AMP Honey H1. He told me months ago that his new DAP would have touch screen, 4.4mm output, BT, maybe Android, but he decided to put this project on hold for the time being.Anything known about the next model dtr2?
If this person on FB has the same direct contact as I have with Anson, then it would be interesting to know a bit more about it.Believe someone mentioned on FB that the next player from Anson will be in 2021.
Still has some ways to go and the DTR1 is showing no signs of aging in terms of performance.
Still hard pressed to find a credible competitor over a year after the DTR1 launched.
If you're keen to try, maybe the FiiO M11 pro Stainless Steel edition. It's the only other player i find that competes well with DTR1.
Power wise the DTR1 still tops the M11 pro SS, but everything else is comparable if not better.
If this person on FB has the same direct contact as I have with Anson, then it would interesting to know a bit more about it.
Regarding the FiiO M11 Pro SS, I never listened to it. How is it better than the DTR1? Can you elaborate further?
DAPs that complement themselves are nice to have. My Calyx M is your M11 Pro SS.Yeah. Still keeping tabs here for your updates (back to lurker mode )
The FiiO M11 Pro SS is more musical, airy, wider staging, a touch more lush and smoother.
Was surprised at how much better it sounded over the standard M11 Pro.
So am rotating between the DTR1 and M11 Pro SS on my daily comments and home use.
Really a nice place to be in at the moment.
DTR1 is cheaper than fiio, so dethonray better in price/performance ratio. For the price it's hard to find comparable players, although I never listened to the fiio. I'm just curious in what areas the next model can get better, maybe I would like little bit wider soundstageBelieve someone mentioned on FB that the next player from Anson will be in 2021.
Wider soundstage can be achieved with the drivers. Just my opinion of course.DTR1 is cheaper than fiio, so dethonray better in price/performance ratio. For the price it's hard to find comparable players, although I never listened to the fiio. I'm just curious in what areas the next model can get better, maybe I would like little bit wider soundstage
Drivers? Do you mean headphones or software?Wider soundstage can be achieved with the drivers. Just my opinion of course.
My bad, I meant earphones or headphonesDrivers? Do you mean headphones or software?
