Random Lunatic
- Jan 9, 2017
Not the same, but very similar, the D9200 had very marginally more in one area, but across the material I tested with, right from the bassies EDM to live instruments, the presentation in that area remained relatively similar: snappy, precise, never straying over the line - even in some cases where you might want it to. That and some deviation in the upper mid-range made it more forward sounding, which by contrast limits the tolerable volume, and thus bass output for me. And both take a sophisticated approach, staying a step away, and handing you every piece of information on a silver platter as needed. Rather than, say a Fostex which will slap you in the face with it, or some warmer headphones which will lean on you and completely envelop you in a blanket of the constant hum and rumble of the music.For me is the 9200 the best closed by far.
The 9200 brings everything you need to EQ it - if you think you need it.
On the other hand, you cant EQ higher quality when you are tired of a bassy HP.
And ....surprised that someone said that the hd800 have same bass as the denon.
Think this is a very unique opinion.
All I'm saying is if you were (as I was hoping for) expecting a D7000 spiritual successor, like the TH900 was, i.e. a monstrous party animal, compared to most 'hifi' headphones, it isn't that. It sounds more sophisticated, like a German headphone. Not that its a bad thing, simply something to be aware of - I certainly agree its the overall best one at the moment, or a candidate at least.
