So they sent me stax009 pads at $150US.
![](https://www.head-fi.org/attachments/2761604/)
So there is positive and negative about these pads.
**Plus**
They are the first and only pads I tried that did not alter the tonal balance hardly. Very slight less lower mids .
Bass was all there, and trebles a very slight more clear without being noticably brighter, but was a hint more.
Mids were very slightly tamed so the image was more spacious than stock and very slightly touch more relaxed or not as close.
Image was just as clear.
This is very important as nothing else but stock and ether electrostat pads were clear.
The Ether were not optimal as they leak bass.
The stax009 pads, on the other hand, do not leak any bass, which is rather shocking, given the larger opening size...
These are fantastic pads to bring the 9200 closer to the slightly more open Utopia image.
*** The negative***
![](https://www.head-fi.org/attachments/2761606/)
The slightly larger size..
Well, now that I have my perfect pad i(the stax009 pad), I have to figure out a way to keep the pads from slipping off(!)...
As they may, if pulled a bit, because they are a bit larger, so they are not a tight fit. They are a loose fit which remarkably does not loose bass, which I believe is due to the high quality of the leather...
Supple wonderful quality leather...
Better than the ether electrostat pads which were nice quality, but much stiffer...
There you go.
The only alternative pad that actually sounds great.
I probably will place some cloth tape inside to center it to the plastic ring..
