Hello, Head-Fi community!
I have been interested in Denon 9200 and see a lot of good comments and positive reviews about this headphones.
I am planing to use it with Astell & Kern SE 180 as portable equipment and with Cambridge Audio CX61 + Topping D90 at home. Is it good choose?
I usually listen ambient, classic rock, metal, and little jazz. How will 9200's in this genres? Or can you recommend another headphones which will good with home and portable equipment.
The Denon is pretty easy to drive, should run off most everything. Heck it sounds good from my pc. Yes, in my opinion it will be good for those genres. It has very good bass extension, clear mids, but is a tad bright in treble. Nothing offensive, your ears will adjust over time unless you want completely neutral from the start.
However, there are hifiman headphones now at great prices. This is something I have learned. But, they are a bit harder to drive planars and most of the good ones are open back.
I would recommend Denon if you absolutely want a closed back.
