les_garten
- Nov 6, 2008
Think about your pin out carefully. I did mine initially in Dual 3 pin because I felt that if I were to hook into a different amp it would most likely be 3 pin. But now I think I should have done 4 pin and made a 4 pin to 3 pin adapter. The 4 pin is lighter and easier to deal with to me. So, I'm going to reterm everything. So I would need a 4 to dual 3 pin and a 4 to SE adapter to cover the waterfront.
Originally Posted by Runkby /img/forum/go_quote.gif what kind of connections are you getting... b/c i may have moon reterminate my cable on the d7000s with one of their higher end cables but i am not sure if i should get it done with a pair of 3pin xlr's or a single 4pin xlr b/c the amp im prob going to get will have both... |
