les_garten
- Nov 6, 2008
I did mine, I could help you out on the phone with any pointers. The cautionary deal is to be very careful with the screws. They are screwed into either plastic or wood and will strip easily. Have the proper tools, take your time and don't get in a hurry. Heat soak means to get your soldering done in about one second of contact time so heat application is minimal.
Originally Posted by tim3320070 /img/forum/go_quote.gif Thanks Les. Given that I don't know what "heat soaking the pads" means, I might be at a disadvantage. I will look into it. I am handy but inexperienced with this type of work. I aggree the cable isn't very ergonomic, it twists way too much at this price point. Moon Audio will do it for me for $50 above the cost of a new cable which almost seems worth it (as he intended it I'm sure). My D7000's have about 30 hours on them and they are sounding really nice, a noticeable improvement over the D5000- more details are heard, tighter bass, not earth shattering but there- I have been A/Bing them. Would I pay $999 for them, no, but at $550 ($180 more than I paid for the D5000), absolutely. If I listened with the D5000 and an hour later I listened with the D7000, I might not know the difference, but quick changes make the differences obvious to my ears. |
