Magick Man
Daddy Warbucks
- Jan 4, 2012
Yep, yep. It smooths it out. It isn't as dramatic as the D2000, but it is an improvement.
The Mark-L mod is supposed to clean up the bass a decent amount. I haven't done it personally, but I bet someone here has.
I sold my D7000 before getting the chance to audition them with the NFB, but from what I know from either component's signature, they would match well. You can also upgrade to a more power-hungry headphone with the 10SE. If you don't plan on a later upgrade and want to spend a little less, I fully recommend the Nuforce Icon HDP.
I would think that the NFB might be too much on the warm side for D7000's.
I have plugged my D7000's into my daughters Sansa Clip and my iPod 5th Gen and they both sound very good.
As long as you don't hear distortion or other obvious problems, I don't see why you would need anything more.
And least try it for a while and see for yourself. You can always buy more stuff later.
I dont hear distortion, just bass that is ovewhelming and boomy. Im many bass heavy tracks (katy perry, Lady gaga, hard rock etc..) i have to take off the headphones. This being on a itouch or creative ZVM. Converseley Dave Matthew Live and other lighter rock do sound very good.
I just thought a dac would tighten and reduce the bass effects, without reducing quality and impact.
Definitly not looking to spend money...but will if it helps.
Hi all. I'm wondering how you might compare the D7k to the planar dynamic cans, especially Hifiman He-4, HE400 and HE 500. I don't have the ability to audition any of them so I'd really appreciate any help trying to decide which to pick... especially if someone here owns both a pair of good planars like the LCD2 or Hifiman500.
I listen to mostly Acoustic, Electronic, Indie and Classical... assume the source and amp will be adequate... I'm just wanting to find out how to compare the quality of these cans without being able to try any of them... thanks in advance for any help.
