Bostonears
- Jan 30, 2003
I would really like to listen balanced vs. stock D7000 and feel the difference. Before that happens, call me skeptical.
cost me 20$. Cut the stock cable near the end, soldered the 4 connectors on to a 4 pin xlr, closed it up again. Voila -done. I also made a TRS to 4 pin connector out of the remaining pieces.
Takes about 15 mins of your time and 20$. But, if you want, you can always send your headphones away and pay someone 300$ plus shipping for essentially the same thing.
Correct me if I am wrong. Isn't that just changing the Stereo TRS connector to XLR? That don't make it balanced.
D7000 has 4 wires coming from the speakers to the TRS plug so reterminating them to 4 pin( or 2x3 pin) XLR does balance them.
ding ding ding we have a w1nnar. There are 4 cables, and are entirely balanced with a simple and easy retermination. The stock wire is a good one too, theoretically anyways... so cable nuts should be able to resist an "upgrade"
I got the Concerto so balanced means a new amp right? Awesome news we can do such an easy balanced mod.
I'm curious, whether iBasso D3+ is powerfull enough to drive these headphones??
Yeah since the Concerto is single ended. I decided on the Violectric 181 or 282 sometime in the future since it will allow both types of use.
Can you please post the cable colors for L&R and ground? I will chop mines as soon as the 4 pin XLR show up in the mailbox.
