Hey Pedro, glad to hear you are enjoying your hd25s.
I've owned the Mdr-1r, didn't find them muffled, perhaps missing some high end extension and definitely no deep sub bass.
I've owned the sony v6 too.
The AH-D600 would be more comfortable than your other cans. It will have better low end extension than your other cans, it will also have a larger more spacious sound.
However it is a colored, and it has a recessed mid range especially compared to the hd25. The hd25 is colored as well though it has a neutral mid range.
I recently got an Hd650 and I can say it has that same neutral mid range but it extends it higher a and lower. Add to that it has some pretty good bass (better than hd25, momentum, mdr-1r) but it doesn't go as low as the D600. It does seem more controlled and accurate within its range and driving it from my Rotel it certainly has enough kick.
It is the best out of my headphone for certain. It needs a headphone amp. The Ah-d600 certainly does not. The d600 is also more comfortable. For listening to electronic music these headphones compete against each other. One gives your more detail and transients, the other more sub bass.
So to get the hd650 running it's going to be an investment. The d600 is ready to enjoy directly out of a portable source. So if you need a closed can at home, one that you relax with it is great. Your ears adjust to its signature.
The main reason I got my 650s were I needed a more neutral headphone for music production and I got. Agreat price on them.
It may be worth saving for something like the HE-500. Can you audition the d600? I bought them knowing that they were not neutral but would give me a fun and very good bass experience
