Light - Man
Thanks SAndreev, I have not read any reviews yet, I just bought on impulse without much research and I think I recall that when I looked for reviews I could not find any.
Are there any links to good reviews?
My experience so far has been a little disappointing but things have gone from not so great to worse than not so great - as the RHS 3.5mm ear plug has a bad solder joint/ connection which I have been able to establish by changing sides, etc.
To me the stock cable is very flimsy for an expensive cables and I would slate them even if they were cheap. As a guy who has made all sorts of cables in the past I am unimpressed how amateurish the cable is made, I don't give a **** if it is 7N or 20N Copper if it has failed already and is likely to fail due to the lack of proper strain relief. There is thick soft braiding over a thin cable, I can only imagine how little Copper is in there!
Another observation is that as a guy with average size ears - there is no extra room in ear pads for someone with larger than average ears.
