Pontius is supposed to have better resolution and soundstageI have always been curious to hear how the Ares II sounds in comparison to the Pontus II. I recently sold my Pontus II, but I will miss it. It's a spectacular sounding DAC, especially when using HQPlayer to upsample to DSD.
DENAFRIPS 'ARES' R2R discrete ladder DAC - close up view
- Thread starter PitBul34
JerryLeeds
- Jun 12, 2015
Does any know how or have a link/video about removing the bottom feet
cpu235
I recently bought an ARES II with the latest firmware in the used market and love it, but I do have a question, would coax/optical sound better than USB? I am currently using USB input but is it worth it to get a cheap DDC like topping d10s so that I could use the coax/optical input? Thanks.
Hyde00
lol your mileage may vary but........ from my experience both Musician Draco and Denafrips Ares II both has "meh" USB.I recently bought an ARES II with the latest firmware in the used market and love it, but I do have a question, would coax/optical sound better than USB? I am currently using USB input but is it worth it to get a cheap DDC like topping d10s so that I could use the coax/optical input? Thanks.
Sound definitely improved even with my super dirt cheap DDC (SMSL PO100).
You could probably pick up a Douk Audio U2 Pro from Amazon or something lol.
I thought USB sounded better than the Douk U2 Pro on my Ares II.lol your mileage may vary but........ from my experience both Musician Draco and Denafrips Ares II both has "meh" USB.
cpu235
I did see the Douk u2 pro and SMSL po100 pro on Amazon, I wish the po100 was still available though, I think they discounted it. Maybe I will pick up something similar in the future.lol your mileage may vary but........ from my experience both Musician Draco and Denafrips Ares II both has "meh" USB.
Hyde00
Ah so yeah might vary from system to system lol.I thought USB sounded better than the Douk U2 Pro on my Ares II.
You can look at the regular Douk Audio U2 (not Pro) if you don't want to spend too much money.I did see the Douk u2 pro and SMSL po100 pro on Amazon, I wish the po100 was still available though, I think they discounted it. Maybe I will pick up something similar in the future.
It's pretty close in price to the discontinued PO100.
cpu235
Good to know! I am gonna look around and see if there are any other alternatives, if not I might just get the po100 pro, I like the design more compared to the Douk u2/pro. Ares II is really a great DAC though for the price, even with USB I think it sounds pretty nice.Ah so yeah might vary from system to system lol.
It's pretty close in price to the discontinued PO100.![]()
sajunky
All depends on your source. Generally noise is higher from PC, but it is not possible to predict results. You can try inexpensive converters, but before spending money it is worth to try self powered USB 2.0 hub to redirect ground loops or commercial redirectors like Ifi Defender.I recently bought an ARES II with the latest firmware in the used market and love it, but I do have a question, would coax/optical sound better than USB? I am currently using USB input but is it worth it to get a cheap DDC like topping d10s so that I could use the coax/optical input? Thanks.
simon740
If you have a good streamer, usb is best for Ares II. Great DAC.I recently bought an ARES II with the latest firmware in the used market and love it, but I do have a question, would coax/optical sound better than USB? I am currently using USB input but is it worth it to get a cheap DDC like topping d10s so that I could use the coax/optical input? Thanks.
cpu235
Makes sense, I am using PC as source but I could try my dedicated power usb hub and see if it helps. Thanks!All depends on your source. Generally noise is higher from PC, but it is not possible to predict results. You can try inexpensive converters, but before spending money it is worth to try self powered USB 2.0 hub to redirect ground loops or commercial redirectors like Ifi Defender.
Unfortunately I am using a PC for this setup, but yeah it is a great DAC even with USB.If you have a good streamer, usb is best for Ares II. Great DAC.
Hyde00
I am also using PC as the source, but I find the issue isn't even the noise. It's more USB timing. Once you switch to a DDC with better timing and feed it with coax or optical (coax has higher resolution, optical is a bit warmer), then I find soundstage and layering open up. Things that related to timing ques.
But anyway, your mileage may vary. Maybe try something cheap and see if it helps lol.
EDIT: This is partially why the higher end DDC usually come with re-clocker.
sajunky
I agree with the above, except:
Depends what you mean reclocker. USB input do not need reclocker. Masterclock is internal when connecting with USB.EDIT: This is partially why the higher end DDC usually come with re-clcoker.
Hyde00
Sorry I just mean the DDC do their own timing as oppose to from the source PC.I agree with the above, except:
Which Fuse size/Volt do i need for EU?
Total: 6 (members: 0, guests: 6)
