Hyde00
Denafrips Ares II and Enyo should be identical. It was just later re-market to Enyo, so you could say it's the newer batch of Ares II but otherwise the same spec.I've come across the denafrips enyo marketed as the ares II? But found price differences.. can someone shed some love ght on this please?
The one that would be different is the Ares 12th. Ares 12th is improved upon Ares II/Enyo. They re-worked the buttons at the front so it's easier to use instead having to use all kinds of secondary layers. There is also sound improvements but I don't know the exact changes.
Basically if you see difference in Ares II and Enyo, something is wrong.
If you see difference in Ares 12th, yes that's normal, this is situated higher than the regular Ares II/Enyo and therefore more expensive.
Hope this helps lol.
EDIT: Oh they also added I²S connection to the Ares 12th, the regular Ares II/Enyo does not have that.
