Even 1 BNC input would make me happy.![]()
Yeah i forgot BNC..how about AES
Venus>Ares? 26 bit vs 18bit with i2S. But use Amanero vs Xmos208 on Ares.
AED would make me happier...![]()
How about USB into i2S . This is likely possible.![]()
My problem with that is my Soundaware Pro I2S out is using ethernet cable and has different configuration than PS anf Audio-gd so it is a not so useful input for me. I am just planning to use coax input at the moment as I find my redbook files really good.![]()
Ok.I just find out some USB input sound better then i2S with MSB dac module![]()
Dealer told me thier Terminator DAC is comparable to Rockna dac which uses MSB dac module. Surprisingly the USB input sound better then i2S on some reviewer of rockna.
I was wondering the xmos208 is using internal power or 5V rail from USB cable. Either way i might pick up a Humandata USB high speed galvanic isolator from Japan which is highly rated in pricing and performance of itona. The ethernet over USB startech too much wiring and power outlets to use![]()
It's the first time I've read this Humandata. Can you send a link about it?
PitBul34,
So have you already compared your new OPPO SONICA DAC with ARES?![]()
