Denafrips Arce
Sep 14, 2023 at 4:34 AM Post #121 of 198
Sep 14, 2023 at 4:50 AM Post #122 of 198
Yes! After only a couple of hours listening I would say it is way better .... 20-30% :wink: Very hard to tell.
Lovely!
I have been thinking about buying T2+ with Arce, so I can use the T2+ clocks to improve the streamer further still. Big investment...
Sep 14, 2023 at 4:57 AM Post #123 of 198
Lovely!
Go for it!
Sep 14, 2023 at 3:36 PM Post #125 of 198
Lovely!
You won't regret it. I've owned my T+ for almost 2 years and don't plan on replacing it, unless it's a T+ 12th.
Sep 14, 2023 at 4:11 PM Post #126 of 198
Which one of your DACs do you intend to replace by the T2+? The Adagio or the S5?
Thx
Matt
The S5. The Adagio is for sale separately.
Sep 14, 2023 at 7:20 PM Post #128 of 198
Sorry for OT. I had so far the impression that you are very pleased with the performance of the S5. May I ask what are your reasons to replace it.
Thx again
Matt
I am happy with it. It's a superb DAC. T2+ is something that's been on my mind for a long time; particularly the idea of using the clock outputs.
Sep 19, 2023 at 8:46 PM Post #130 of 198
Sep 20, 2023 at 1:06 AM Post #131 of 198
Despite the occasional stutter I have such an improvement in sound quality it will be worth it in the end. It is truly a shame the I2s has not been sorted out with a standard. Evan when pairing Denafrips to Denafrips it is a bit of trial and error with the settings, at least you don’t have to fiddle with pin outs on plugs.
Sep 20, 2023 at 1:28 AM Post #132 of 198
In my system, as a ROON bridge, the AURALIC G1.1 USB to PONTUS 12-1 with the ARCE COAXIAL to PONTUS 12-1 sounds very similar. But compared to the overall functionality and APP of the G1.1, the ARCE is a long way off.
As a ROON user, I am very happy with the ARCE.
Sep 22, 2023 at 11:44 PM Post #134 of 198
The funny thing you would think Denafrips would recognize its own kin but you need to kind of trial and error the config to make it work. Good thing there are only 4 different settings on the dac to change. I am surprised changes in digital processing would make such a difference, when they say bit perfect delivery it would all be the same.
