Comparison "Monster Dac" with USB - isolated XMOS - I2S interface VS Low Cost AK4495SEQ Dac with RPI3 - DAC+Pro - I2S interface:
Setup:
1- HP Probook i7 - 16Gb RAM - Server 2012 - 2x 250 GB SSD - Audiophile Optimizer - JRiver as player - connected with USB to "Monster Dac"
2- HP Probook i7 - 16Gb RAM - Server 2012 - 2x 250 GB SSD - Audiophile Optimizer - LMS server (Logitech Music Server)
Both JRiver and LMS server running simultaneous on HP Probook.
Both "Monster Dac" and Low cost AK4495SEQ Dac use LME49720 as output stage.
To begin with:
I bought the low cost Chinese AK4495SEQ last year, just to check out the performance and sound characteristics of AKM AK4495SEQ chip.
Since I wanted to build a new dac I could decide whether this chip had a sound character I liked and if I would base my new dac design on it.
This little baby performed very well, but in it's stock version it was not as airy as I had in mind, so I started to mod it with lots of Nichicon FG caps,
Cree diodes, different opamp as output stage and more. At the end it sounded fabulous, especially when I connected Diyinhk Isolated Xmos to it.
The design of this dac incorporates 1x psu for output stage, and 1x psu (with several regulators) for Digital section.
Since it's fabulous performance I decided to build my new dac, based on this AK4495SEQ chip.
I started designing and building and eventually finished my "Monster Dac"
First listening sessions I was amazed about it's airyness, bass control, big deep wide soundstage, lots of blackness around voices and instruments.
It was a huge step forward from the little baby.
So, where are we now, today?
I connected both dac's and played 2 albums on them, running simultaneous from HP Probook.
If I wanted to switch between dac's, I only had to switch between them on my pre-amp.
To begin with, they sound almost identical!!!
- Monster Dac has a little better bass control (and definition in it's lower frequencies), it's a tiny bit more airy, and it seems (not 100% sure) if it's more quiet, more black around voices and instruments.
- RPI has better vocal body and seems to have more 3D artifacts. It's bass output is more evident.
The two are VERY close to each other in this setup.
Conclusion:
Since low cost AK4495SEQ performed incredibly different when using isolated XMOS, it couldn't walk in Monster Dac's shadow, I have to conclude that:
RPI3 + DAC+ Pro > I2S output > based on PiCorePlayer and LMS server, is running circles around isolated xmos solution.
It's a VERY good performing solution!
AND
Keep in mind, RPI3 + DAC+ Pro together cost around $100. Software (LMS server and PiCorePlayer) are freeware.
Isolated XMOS interface cost about the same, but it needs:
1- Very stable OS and drivers
2- Optimized OS for Audio only
3- Powerful CPU
4- Needs to pay for Player software if one wants to remote control it with Graphical Interface on iPad or Android device
5- Needs optimized USB port on PC
6- Needs USB optimizing equipment like Intona / Regen / iFi purifiers and others (which will let you break the bank.......)
7- Needs high quality USB cable (which will let you break the bank.......)
Keep in mind, I also installed LMS server on my Daily work laptop, which I am typing this review on.
I connected PiCorePlayer to this LMS server (it finds it automatically in the network) and played music from it.
There was NO sonic difference between Setup-2 and this setup!!! So, NO need for expensive hardware to run LMS server!!!
Second thought:
You can use RPI3 + DAC+ Pro in every room in your house, if you have network connection. You can use same LMS server, and, even Analog output sound quality of RPI3 + DAC+ Pro is rather good!!!
I suppose that there are many expensive dac's out there which perform much less than this little baby! (if connected separate psu's the way I did).
Final thoughts:
I will have to modify my Monster Dac to replace it's I2S interface with RPI3 + DAC+ Pro combo, more on that next week or so
Last word:
Since this RPI3 + DAC+ Pro combination is performing that well, it asks for the best of the best, which is Ian Canada's FIFO II solution with Isolation board and Dual XO II clock board.
I ordered them today, so, let's have some fun the next weeks
Wish you all a prosperous week
Alex
