- Apr 11, 2006
For the ones who finds my Raspberry Pi 3 + Hifiberry DAC+ Pro project interesting:
After 5 days of burn-in time I have to conclude that "first impressions", until now, FAR exceeds what I've expected!!
What I did:
1- I took a basic RPI3
2- I took a HifiBerry DAC+ Pro and soldered a 2-pin header for external 5V power, and a 5-pin header for I2S output.
3- Mounted HifiBerry DAC+ Pro on Pi3's top
4- From Hifiberry website I downloaded latest installer and installed PicorePlayer for DAC+Pro on MicroSD card
5- Connected I2S to an older AK4495SEQ dac
6- Powered RPI3+DAC+ Pro with ONE 5V (diyinhk 0.8uV ultra low noise psu), so NO power input thru RPI's Micro-USB input
Things to consider:
The AK4495SEQ dac I used for this test was a previous one I used before I started my "Monster Dac project".
This dac is sounding very well, but has an integrated power supply on board, it's a very big difference in SQ in comparison with my "Monster Dac"
It's native SQ (connected to diyinhk isolated Xmos - just as in "Monster Dac") is a much less open sound character, less detailed and more compressed soundstage.
Low frequencies are not that detailed, mid frequencies are not as natural, and it is not that airy (black around voices and instruments).
On this AK4495SEQ dac I used a NEW "simple LME49720 - plastic version" opamp as output stage. This one hasn't burned-in yet too.
The previous impressions:
Listening to this set during the past days was not that good at all, at least, in comparison with my "Monster dac". It changed every day in a positive way, but it didn't please me at all.
(Don't forget that I am used to a very open soundstage, very natural sounding, very airy, just better than any analog I have ever heard, with massive Bass control which reaches to the
deepest registers I've ever heard (and felt...))
The soundfield was a bit fuzzy, no pinpoint precision, lack of bass control - but more powerful deep-bass. Voices seemed to sound different, not sure how to explain.
So, how did the RPI perform yesterday, after 5 days of burn-in time (needs at least 7 days):
What I heard yesterday was amazing. I didn't expect this at all. It seemed that the soundstage had widened, A LOT, maybe even wider than my monster dac!
There were several occasions where I heard lot's of phase-tricks in recordings, sounds which seemed to went out of the room, behind my head, everywhere!
There wasn't any listening fatigue anymore, pinpoint precision was almost as good as my monster dac, bass was VERY deep and powerful, but still lacks control.
But, what amazed me the most was it's sound character in total, not sure how to describe it, it's like, when comparing to my monster dac, the sound is more massive,
it surrounds you and it seems voices have much more body and impact. It's almost as if my monster dac is sounding pinched, more like a studio recording, while RPI is more
like a live concert, more rhythm and pace, it's just there!
I can't imagine how it can sound when properly powered, fully burned-in, and connected to my monster dac instead if the isolated USB XMOS I've built in.
I expect bass control to be better in the coming days because I know this opamp really needs it's burn-in time, and pinpoint precision and details will also gain.
These are wild days in Audioland, heard a lot of "rumors" of using rpi for audio, but now I know why, it has a phenomenal potential, and, I will explore those completely![]()
To be continued.....
After 7 days of burn-in I listened again to RPI and DAC+Pro.
It really sounds VERY good!
Of course it's not that airy as my monster dac, and also bass control is less, but that is something which is inevitable when using this AK4495SEQ in comparison to my "monster dac".
It still has a very wide soundstage, very 3-dimensional sounding, and it has a beautiful "punch", full body.
I couldn't wait and powered 3.3V and 5V for DAC+ Pro external. This improved it again. It's a combo I could live with, definitely!
Very curious how it would sound in combination with my "monster dac", but that has to wait since I sold my "monster dac" to a friend of mine.
Since the DAC+ Pro uses mediocre TCXO's from ExpressO, it can't reach the best quality. And, sadly those tcxo'x can't be replaced very easily because they have
an on/off function. This means I would have to design a relay board before I could use NDK's.....
I will investigate this further, I'm very eager to try the Ian Canada FIFO II - Isolation board - Dual TCXO board, this should bring it to an absolute phenomenal SQ level.
The Ian Canada solution is independent from quality of clocks at it's input because it rebuild / regenerates everything completely new. But it has it's pricetag....
Regards,
Alex
Comparison "Monster Dac" with USB - isolated XMOS - I2S interface VS Low Cost AK4495SEQ Dac with RPI3 - DAC+Pro - I2S interface:
Setup:
1- HP Probook i7 - 16Gb RAM - Server 2012 - 2x 250 GB SSD - Audiophile Optimizer - JRiver as player - connected with USB to "Monster Dac"
2- HP Probook i7 - 16Gb RAM - Server 2012 - 2x 250 GB SSD - Audiophile Optimizer - LMS server (Logitech Music Server)
Both JRiver and LMS server running simultaneous on HP Probook.
Both "Monster Dac" and Low cost AK4495SEQ Dac use LME49720 as output stage.
To begin with:
I bought the low cost Chinese AK4495SEQ last year, just to check out the performance and sound characteristics of AKM AK4495SEQ chip.
Since I wanted to build a new dac I could decide whether this chip had a sound character I liked and if I would base my new dac design on it.
This little baby performed very well, but in it's stock version it was not as airy as I had in mind, so I started to mod it with lots of Nichicon FG caps,
Cree diodes, different opamp as output stage and more. At the end it sounded fabulous, especially when I connected Diyinhk Isolated Xmos to it.
The design of this dac incorporates 1x psu for output stage, and 1x psu (with several regulators) for Digital section.
Since it's fabulous performance I decided to build my new dac, based on this AK4495SEQ chip.
I started designing and building and eventually finished my "Monster Dac"
First listening sessions I was amazed about it's airyness, bass control, big deep wide soundstage, lots of blackness around voices and instruments.
It was a huge step forward from the little baby.
So, where are we now, today?
I connected both dac's and played 2 albums on them, running simultaneous from HP Probook.
If I wanted to switch between dac's, I only had to switch between them on my pre-amp.
To begin with, they sound almost identical!!!
- Monster Dac has a little better bass control (and definition in it's lower frequencies), it's a tiny bit more airy, and it seems (not 100% sure) if it's more quiet, more black around voices and instruments.
- RPI has better vocal body and seems to have more 3D artifacts. It's bass output is more evident.
The two are VERY close to each other in this setup.
Conclusion:
Since low cost AK4495SEQ performed incredibly different when using isolated XMOS, it couldn't walk in Monster Dac's shadow, I have to conclude that:
RPI3 + DAC+ Pro > I2S output > based on PiCorePlayer and LMS server, is running circles around isolated xmos solution.
It's a VERY good performing solution!
AND
Keep in mind, RPI3 + DAC+ Pro together cost around $100. Software (LMS server and PiCorePlayer) are freeware.
Isolated XMOS interface cost about the same, but it needs:
1- Very stable OS and drivers
2- Optimized OS for Audio only
3- Powerful CPU
4- Needs to pay for Player software if one wants to remote control it with Graphical Interface on iPad or Android device
5- Needs optimized USB port on PC
6- Needs USB optimizing equipment like Intona / Regen / iFi purifiers and others (which will let you break the bank.......)
7- Needs high quality USB cable (which will let you break the bank.......)
Keep in mind, I also installed LMS server on my Daily work laptop, which I am typing this review on.
I connected PiCorePlayer to this LMS server (it finds it automatically in the network) and played music from it.
There was NO sonic difference between Setup-2 and this setup!!! So, NO need for expensive hardware to run LMS server!!!
Second thought:
You can use RPI3 + DAC+ Pro in every room in your house, if you have network connection. You can use same LMS server, and, even Analog output sound quality of RPI3 + DAC+ Pro is rather good!!!
I suppose that there are many expensive dac's out there which perform much less than this little baby! (if connected separate psu's the way I did).
Final thoughts:
I will have to modify my Monster Dac to replace it's I2S interface with RPI3 + DAC+ Pro combo, more on that next week or so
![wink_face.gif](http://files.head-fi.org/images/smilies/wink_face.gif)
Last word:
Since this RPI3 + DAC+ Pro combination is performing that well, it asks for the best of the best, which is Ian Canada's FIFO II solution with Isolation board and Dual XO II clock board.
I ordered them today, so, let's have some fun the next weeks
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
Wish you all a prosperous week
![beerchug.gif](http://files.head-fi.org/images/smilies/beerchug.gif)
Alex
