DDC - Digital USB interfaces - Xmos or Amanero Combo384 based - Raspberry Pi - HifiBerry DAC+ Pro - reviews, comparison, modifications and USB-Audio in general
Apr 15, 2016 at 5:48 AM Post #316 of 569
The plot thickens :)
And 'jan's stuff' looks larger than expected. IIUC, the first board in your pics has the i2s chips and second one the clocks .. but what exactly does the third one?
Apr 15, 2016 at 6:00 AM Post #317 of 569
The plot thickens
The third one is the isolator board which has to be connected between FIFO II board and Dual XO II clock board. Pcb's seems of very high quality
Apr 15, 2016 at 6:10 AM Post #318 of 569
Hm guess you'll need a taller case to fit the entire rpi+ian stack into your monster dac.
And it may not fit into mine.
Anyway, wish you luck with the experiment and can hardly wait for the next sq impressions.
Apr 15, 2016 at 7:06 AM Post #324 of 569
Friend of mine is an audio diyer, he build this Raspberry PI3 recently, and pairs it with a diy R2R DAC. The acoustic playback is astonishing, it outperforms my brother's Naim flagship system entirely. I shall upload more images later on.
I upload all these images via my mobile phone, so it was a bit clumsy. .
Apr 15, 2016 at 7:23 AM Post #325 of 569
Cool stuff. Sounds like the future to me :)
Also, I'm trying to figure out if such an rpi stack would fit into my current Minimax Plus Dac.  Do you know approx how tall is that case? And/or how tall is that rpi stack assembly inside it?
Apr 15, 2016 at 8:06 AM Post #326 of 569
Yes, I will need a case which has a greater height, 9CM instead of 7CM, then I can put different R-Core in the enclosure, mount them on their side,
this will give me room enough to place all the pcb's.
I suppose rpi+DAC+ alone will be very very good, without fifo-isolator-dualdacboard, so that is maybe the way you should go.
The pcb's are not that big, but they won't fit in your dac
Apr 15, 2016 at 8:10 AM Post #327 of 569
That looks great! (except for the scews in the sidepanel, hahahaha).
What kind of R2R dac is he using?
Regards,
Alex
Apr 15, 2016 at 8:16 AM Post #328 of 569
Does your brother have the Naim Audio NDS? It's about $13.000
Apr 15, 2016 at 9:20 AM Post #330 of 569
The pcb's are not that big, but they won't fit in your dac :(
Yap, was afraid of that. Not that much space inside my minimax. Your current rpi+berrydac stack might fit though.
