Crystek CCHD 575 TOTL ???? That's NOT so obvious to me, but they are close to NDK
Pricing? About USD 25,00 for the Crysteks, USD 8,00 for the NDK's (45.xxx mHz and 49.xxx mHz even only USD 4,00 at Jlsounds)
Freq CCHD575 NZ2520SD
10Hz -100dB -113dB
100Hz -130dB -140dB
200Hz -138dB -142dB
400Hz -145dB -148dB
1000Hz -150dB -153dB
10000Hz -162dB -158dB
100000Hz -164dB -158dB
F-1 V1.0 looks great btw! But very expensive, about USD 150,00 excluding shipment.
NDK's are by far the best option. clearly when comparing to crystek.
the low end all the way to 1000Hz are quite important as no other clocks come close to this performance. -13dB less for 10Hz is very significant, and this is comparing to an already stellar performance crystek! NDK's are definitely the best option. And as you said, the cost difference is also a factor. this is a no brainer if you were designing a DDC the choice would would be NDK.
I'm quite happy with how my DIU8 sounds with the NDK's i've installed.
Too bad there isn't any of those new Xilinx chipsets that are using NDK's. Otherwise i'd might be interested to give them a go.
those IFI products are quite neat if you need them. I own just about one of each. well specifically the Ipurifier2, Dc Ipurifier, and the dc wall wart 12v model.
I tried the Ipurfier2 inline after my Intona before going into my DIU8 yet experience no change...total bummer. I'll be using this in my wifes setup.
I am however using the DC ipurfier with my teddy pardo lps and it did help a tiny bit, as the teddy is known to have a few spikes of noise down in the lower freq, but maybe this is all in my mind. I'm going to use this device in my new dac build (dual dam1021's with luckit waveiO and hdmi i2s input) the teddy will power the waveIO, and Hynes will power the dac's.
the last device, the dc wall wart from Ifi i've had for many months yet never realy thought much of it, as now it's just used to power a silly device I bought like that revive 777 thing? it's some low freq generator that certainly is a scam and waste of time and money. But at least I tried it. And it's powered by the ifi wall wart now.
All the ifi products are actually pretty damn good for the price, albeit they had little effect in my system, and some had no effect. I think my balanced A/C system tends to set the bar pretty high for having ultimately the lowest noise floor possible.
I'm pretty much done playing around with ddc's for the moment. The LuckIT waveIO (uses NDK's go figure, and has 7 ultra low noise voltage regulators/3 LDO's LP5900 6uV noise for clocks) will be the heart of my new dac project and I can't wait to hear it's potential. I'm sure it will take the cake and dominate all the DDC's i've heard. I almost went the round of JL sounds USBoverI2s module (also uses NDK's go figure, not sure if it has as many regulators, but does also have 3 LP5900 6uV LDO's for clocks) as it's spec'd better than everything out on the market today...yet it's not clearly the best option for my build. I know it will work, but was a bit more complicated and needed two separate PSU's to get the full effect. I may try it at a later date. But I plan to implement direct DSD with my new project... or the best dac is no dac...Acko is working on a dsd project that taps off the i2s lines to feed true native dsd out into analog. Has a lot of promise and it will be out soon. it doesn't need a dac, just a great usb module like WaveIO, Amanero etc etc.
