- Apr 11, 2006
Yes, I know them, but they are not comparable with Ian's fifo reclock. Still, they are a good choice to use too!
Actually, what I think he is talking about there is the USB clock.
makes my DAC look like a LEGO set.
Only thing I really would want to try is the Ian (IanCanada) FiFo II Reclocker and Dual XO clockboard. I am very sure this would be the best achievable SQ. But for now I am
One other thing to consider, the Soekris DAM 1021 R2R DAC at 195 USD comes in about the same as either of the TP or IanCanada Reclocker boards
plus it gets around all the annoying little RPi issues as it has an isolated I2S and reclocking FIFO
A feature Soekris added recently is DSD, the FPGA will convert DSD to PCM on the DAC.
Performance wise, with the powersupplies you already have, it will run rings around just about any mid range (<1500 USD) Delta-Sigma DAC out there.
https://soekris.com/products/audio-products/dam1021.html
Hi B0bb,
Thanks for the precious info! I did look into the Soekris a long time ago, didn't know it had DSD capabilities already by now!
Btw, my DS dac already runs rings around much more expensive dac's![]()
But, to be honest, I am looking into a new project which seems VERY interesting. It is based on DSD, directly from I2S, and NO dac needed.
See the link below, it's VERY promising!
http://www.diyaudio.com/forums/digital-line-level/273474-best-dac-no-dac.html
Any thoughts?
Hi B0bb,
Any thoughts?
Any thoughts?
Any thoughts?
That is an interesting project, are you one of those on the waiting list ?
I have been looking at the one from ACKO
http://www.diyaudio.com/forums/group-buys/280763-direct-drive-dsd.html
The same concept plus it has an integrated isolator and reclocker that allows me to use the high stability XOs like the Crystek and NDKs.
PCM is the main stumbling block and required very high quality conversion to mask the artifacts from the lossy conversion to DSD.
I use JRiver and only convert at 256fs or higher.
For the moment I stopped using rpi with dac+pro, compared to SinglePC (one pc died last week) server 2012R2 /AO / JPlay, and I must admit, SinglePC is much more airy.
I had troubles with previous DualPC setup, seemed the old AMD (12yo) didn't perform as expected. SinglePC (i7 16Gb RAM) performs a lot better.
Will try HQPlayer, I am not very fond of Jriver's DSP modules. Trials are available.
Yes, I prefer with isolator and fifo reclocker too, Nautibuoy pointed me to BeagleBone Black with Acko S03, probably will try that too, seems better to me.
