I have a handful of SACDs but haven't played them in a long time. I had a Philips SACD1000 that died once, was fixed by Philips, survived a while longer, and then mostly died again. This was the infamous Furore chip failure fiasco circa 2003 if anyone cares to google it. I still have the unit stashed in a closet somewhere in case I ever want to harvest parts off it for other projects, and I never bought another dedicated SACD player. I'll look through the discs and bring a couple of the better ones.
I have a couple of redbook CD players I "could" bring... a thrifted Sony CDP-750 (TDA1541 DAC) that I've recapped and tweaked slightly with a better op-amp and low jitter clock. That one is analog output only.
I also have an early-1990s Philips LHH500 in champagne gold color. Opulence... I haz it. That was a pretty well-built machine in its day with a CDM4 swing arm transport, robust power supply, nice component quality, proper relay-muted outputs, etc. It was one of Philips' high-end forays into bitstream and has 4 DAC chips, two per channel in differential configuration. I've replaced all 8 of its op-amps (4 each in the unbalanced and balanced output sections) from the old JRC NE5534s to LME49990s and that really woke up the sound. It has unbalanced RCA and balanced XLR analog outs, and coax & optical digital outs. In addition to being more versatile for hooking up to other gear, its analog outs also sound a little better than the Sony's, so the Sony might stay home.
