BenF
- Jan 22, 2013
TG-38S is much easier to drive then Havi B3 Pro MK1.
Stay updated on headphones.com at their sponsor profile on Head-Fi.
I'm on like 37/120 on my x5 with the tingo and 50/120 with the havi, on the galaxy s3 I was around 30% with the tg-38s and 50% with the b3. On the dragonfly v1.0 I am like on 6 on windows volume mixer thing with tingos and 16 on the havis.
If you think the bass is anemic - something is fishy. Are you using ear foams? If you manipulate the TIngos so they are pointing towards your ear canal - and then make the seal better by pushing them against your ear - see if you get more bass.
but if your bass is still anemic after that - I suspect you have a defective pair.
I just tried again my TG-38s this morning after his first 16 hours of burn-in.
Same status as before, sound is the same as opening from box for now, bass is totally anemic (not punchy at all, very soft and poor), other frequencies also excepted still sibilant highs. Highs looks technical and pretty interesting although.
I'am wondering if I'am the only one here to think that TG-38s is more sounding "live", is this normal? it's like I'am watching a live concert in every musics I listen to. Maybe it could be due to my own pair.
Moreover it sounds to me a bit like if we put an EQ to "pop" thing by default, maybe because I'am used to "V" signature earbuds?
One another thing, is the sound power. I have to put each of my sources at a very high volume to expect a low/normal sound from these tingos. So I confirm I have the same problem as pokenguyen. Even my PK1 with 160ohms without amp are less demanding to get a normal volume sound.
Let's now still continuing burn-in process.
Well, given the tg38s a try, and it sounds slightly worse than my diy pk2. Needs a little more power as well. The bass is slightly less, although vocals stand out a little better. I'll give it a try with classical later. I think I am hearing a little more detail than dasetn's take on the pk2, but I'm not sure.
The bass does leave much to be desired. It's a more mid/hi centric bud which I was hoping for a more balanced bud.
If you want a more balanced earbud, Baldoor EarBell is the way to go.
The tg38s fits me perfect
