Tingo TG-JL1 review:
This is supposed to be TG-38S' big brother. But is it possible to improve on perfection? Probably not - but you can try to redefine it.
TG-Jl1's main attraction is its mids - thick and lush. I've said before it sounds "heavenly" - and I stand by it.
If TG-38s is Havi B3 Pro MK1 in earbud form, TG-JL1 more reminds FAD Heaven IV - although not as bassy.
In order to achieve these mids, something had to give - the bass hits not as hard nor as tight, treble is not as extended, and the soundstage is smaller.
The bass is now somewhere around ANV3SE level, so it's still pretty good. FIIO E12's bass boost definitely helps.
Soundstage is still pretty big, larger than PK1 and PK2, on a level with M760.
Detail retreival is almost as good as TG-38S, better than the rest.
The build is much better than the PK series - the black tungsten coating of the shell makes it look like an expensive item.
Weirdly, there is no "Tingo" anywhere.
The cable is the same as on Dasetn PK IE8 - with a chin slider and a nice plug.
Next to it, the 160$ PK1 looks like a Dickensian orphan.
If I had to guess which one costs more than 5 times than the other - I would have never guessed correctly.
TG-JL1 feels a little bigger than PK1, possibly due to the coating. Took a lot of fidgeting to place them correctly in my ears.
TG-JL1 isn't hard to drive, but needs more power than TG-38S.
Overall, I have to place it behind TG-38S, even though some people may prefer TG-JL1, especially with vocals.
It will come down to sound signature preference more than to technical abilities.
And if you haven't heard TG-38S - you may think it simply doesn't get any better.
Considering it's sound, price, looks, and a possible collectible status - highly recommended!
http://www.aliexpress.com/item/Tingo-tg-jl1-dual-voice-coil-croons-earplugs-double-circle-earphones-38s/1820018644.html
