TYATYA
After digging this 4room my choice is
Just give it some more time. At first I thought the same with my Russian Tung Sol. After 4 days there was still no improvement. But after 4 days it became better and better.
It's correct that a Headphone with only 32 Ohm is not the best combination. I've had the samen. Now I have the Sennheiser HD650, and it is way better! Nog only because of the better cans, but the combination is great!
5692 will work fine on the DV. Out of interest what power tube are you using with the Slyvania 5692
Any thoughts on using 336SE purely as a preamp for stereo listening? few front and back tube combination in preamp would be highly appreciated.
Music would be mostly instrumental, Jazz, fusion and some vocals mix. I love tube sound and lean on good bass impact, the gear is modest, SMSL M8 DAC and the preamp will be feeding a Monoprice 11497 300 Watts 2 Channel Amplifier to a pair BIC RTR-EV15 Floor Speaker with High-Efficiency Horn Tweeter.
I'm using it as a pre-amp with good results. There is some audible hum even with pretty much all tubes I tried, but not detectable when the music is playing.The Fitz mod should help but I haven't tried it yet. As for tube combination, you really need to try and see for yourself as it is all very system and ear dependent. I haven' t tried any exotic tubes but and my favorite inexpensive combos so far, grey glass WWII era military RCA 6SN7GT/GE6080, and Sylvania chrome-top tall bottle 6SN7/RCA 6AS7 (JAN- military spec). Generally you want to pair a bright and a warm sounding tubes together, from my experience bright-bright and warm-warm pairs are too extreme combination. I found tube sockets are crap, and there is a good amount of very loud popping and scratching noises every now and then with some older tubes, rocking the tubes back and forth usually helps for some time as does cleaning the pins with very fine sandpaper, followed by cleaning with 97% ISO alcohol and finally deoxit applied.
If you don't plan to use it with headphones you can have a look at Schiit Saga instead, it is more expensive but it has a remote control and only one tube to roll.
Anyone has any thoughts if taking the line-out after the first tube may yield some benefits? There should be less gain which would work great in my case as the output is already too hot for my power amp.
