Darkvoice 336i & 336SE Tuberolling PartII
May 16, 2021 at 2:40 PM Post #10,546 of 14,501
You must be the president and sole member of the 'Bill Cowen Fan Club'! I hope Bill pays well. 😄
I believe he uses cryptocurrency, good luck with that 😁
May 16, 2021 at 2:44 PM Post #10,547 of 14,501
May 16, 2021 at 3:12 PM Post #10,548 of 14,501
May 16, 2021 at 3:13 PM Post #10,549 of 14,501
May 16, 2021 at 3:50 PM Post #10,550 of 14,501
May 16, 2021 at 4:29 PM Post #10,551 of 14,501
He does....even Bangybang accepts bitcowen....
LOL! I like that! Now we just need someone famous to spout about BitCowen (maybe get Bezos or Buffet or someone), buy a whole wad at $0.001, and then dump it all when it hits a dime. If you'd put $10,000 into Dogecoin at $0.003 back in December, it'd be worth $1.7 million right now. Then you could go on a shopping spree at wege_high_tubes and get at least a decent quad of something. :stuck_out_tongue:
May 16, 2021 at 4:38 PM Post #10,552 of 14,501
Or the other way around, put $1.7 million and end up with 10K of things went south 😜
May 16, 2021 at 4:58 PM Post #10,553 of 14,501
That would only cover the shipping cost from wege_high_tubes. Tube(s) not included. :laughing:
May 16, 2021 at 5:07 PM Post #10,554 of 14,501
May 18, 2021 at 9:41 AM Post #10,555 of 14,501
I'll xpost this from the Crack thread, since it applies to my DV as well...
Anyone have strong opinions on a 20k Alps Blue vs. a 50k Audio Note pot vs. a 20k eBay "DACT-style" stepped attenuator? I've got the attenuator in there (both) now, and it works fine, but I don't particularly know what to expect in differences... and it takes me so long to swap a pot out that I can't remember specifically what I heard from the last one.
I am somewhat inclined to put the Audio Note in my Crack and probably the Alps in my DV for the (stupid) reason that they're solid shaft whereas my attenuator is a split knurled shaft... I know that's a fairly stupid reason, but there are many stupid reasons, and this one is mine.
May 18, 2021 at 10:10 AM Post #10,557 of 14,501
Dual 6SN7 6BL7 TO 6AS7 tube adapter For Elise amp is this bad idea in dark voice
I'm confused by the description... does it turn a 6AS7 socket into two 6SN7 tubes? I think this might not be a great idea in the DV... the 6AS7/6080/5998 power tube does its job quite well. If you want to adapt it, I'd recommend tracking down a 6AS7 to dual A2293 adapter.
Incidentally, I think the reason that eBay listing says "doesn't work with Darkvoice" is because the adapter itself won't reach all the way down to the DV's 6AS7 socket without adding a tube saver. DV's sockets being recessed as they are means that a lot of the adapters sold on eBay won't actually work with it. Electrically they're fine, they just aren't long enough. A tube saver mitigates this issue... as does buying your adapters from @Deyan
May 18, 2021 at 10:28 AM Post #10,559 of 14,501
May 18, 2021 at 5:38 PM Post #10,560 of 14,501
With all the help Fiinegan is doing, you may want to add a cat logo to the Incubus plate 😃
That's a really good idea. Maybe even change the branding to Finnegan by Incubus.
