bcowen
OK, but here's where I'm confused... the schematic for the shunt mod has the 3rd and 2nd sets of pins connected to ground with pin 1 having both input (through the resistors) and output soldered to it. Which is what I did.
Edit to add: I haven't really soldered the pot itself multiple times, I've resoldered the components away from the pot but it's been where it is since I initially popped it in there.
That diagram is correct for a shunted wiring scheme (middle sketch). The pic I showed is for an un-shunted wiring scheme (left sketch). So if you want to shunt, use the middle sketch. If you want to try it without shunting, then use the left sketch (which is what I tried to illustrate in the photo). My apologies for confusing things with the "wiper not connected to ground" comment...I was thinking only of the standard wiring connections with no shunts employed.
