bcowen
I’ll try a higher temp for the next pin job. I see your logic here for de-soldering as the shortest amount of time the better. I’d also note that using a liquid flux would be a good idea? I always use a flux dispensing pen. Now is it recommended for pins?
If I'm being lazy and just doing a reheat and adding a bit of solder I don't mess with the flux. If I'm doing a proper 'good audiophile' suck'n'resolder, I add a little flux just to help clean out the internals (being careful to wipe any excess off the outside of the pin before heating it). I like this paste flux just 'cause it's easy to dispense and easy to control where it goes, and the tip on this particular one is exactly the same diameter as an octal tube pin. But any good flux would serve the same purpose.
https://www.amazon.com/MG-Chemicals...ywords=mg+chemical+flux&qid=1605983192&sr=8-5
