KT88
- Nov 7, 2004
Not as far as I know, what info would you like to know? I think it would be better to open a new thread about it.
Originally Posted by jigster /img/forum/go_quote.gif Would the 6336B tubes fit in where the 6AS7 is? Can this tube be used? |
Originally Posted by PFKMan23 /img/forum/go_quote.gif I would make sure your transformer can handle that as the 6080 draws 2.75A of heater current and the 6as7 draws 2.5A whereas the 6336 draws 4.75A (and the 6528 draws 5A). That's my major consideration. |
Originally Posted by jigster /img/forum/go_quote.gif Thanks for the quick response! I was actually asking in context of the Darkvoice... but I got a feeling it cant. But those tubes do look wicked. |
Originally Posted by PFKMan23 /img/forum/go_quote.gif Honestly it doesn't matter if it's a Darkvoice/SP/Zana Deux, any tube amp has a transformer which has a rating of X amount of amps that it can draw. If you put in a tube that draws too much heater current you can fry the resistors or/and take out the transformer. So while the pin out may be the same, you need to be mindful of that. My view is until you can find the specs of the transformer, confirm that it is safe and that it fits, I'd stay away. |
Originally Posted by jigster /img/forum/go_quote.gif How do i check? My DV doesnt have a manual. |
Originally Posted by keanej6 /img/forum/go_quote.gif so from i've read this amp accepts 6SN7 type tubes in the front and 6AS7 types in the back. I'm very new to the world of tubes but i've done some reading/research to become more familiar with them. from what i understand the 6AS7 tubes are the 'winged' tubes that bulge out in the middle, but from other people's pics i see that many people use different shaped tubes. does the shape have anything to do with the type of tube or are all the tubes i'm seeing still 6AS7 types? i'm pretty sure that's not the case. anyways can you tell me which tubes are compatible with this amp so i can begin tuberolling without the worry of blowing it up. or direct me to a thread/resource i could've missed to answer my question. thanks. |
