KevDzn
- Jan 23, 2017
Unfortunately, internal memory is decreased quite a lot, which means you have to rely on sdcards, which often leads to the issue of Spotify or Tidal reverting to internal memory for offline storage on reboot (due to the fact that their handling processes start before the external sdcard is mounted), making the sdcard useless when it comes to Spotify/Tidal...
Which model are you referring to to?
Dp x1/A has 64gb internal memory, 2 SD card slots and you can offline tracks to internal/SD. In tidal app you can choose where to save offline. And no it won't revert back to internal memory upon reboot or restart.
