Timoteew
I've recently made the switch to Tidal to stop spending money and CDs and having to maintain my FLAC library! I'm currently torn between the Fiio M11 as an all-in-one solution and the Fiio Q5S to stream via my phone.
Was looking at this too for an LDAC/Tidal offline standpoint and one review said you can only write to internal memory which is pretty worthless at 2gb.Anyone using the Fiio M6 as an offline streaming device?
New kid on the block
Sony Nw-ZX507 64GB Walkman Hi-Res Digital Music Player with 3.6" Touch Screen, Aluminium Body, Android 9.0, S-Master Hx, DSEE-Hx, Wi-Fi & Bluetooth and USB Type-C
may want to check hereCan i i use Spotify offline on my ibasso dx160 without play store?
does Spotify offline work with Dx200 without play store?Ibasso DX200 and FiiO X7ii.
Both work very well with Tidal offline. At the moment these are best android daps available.
https://twister6.com/2017/09/11/fiio-x7ii-wam3a-vs-ibasso-dx200-wamp3/
My Hiby R6 Pro works with the microSD card and Tidal Offline.
.Does the FiiO M11 (+Pro) and the Hiby R6 (+Pro) really support the full resolution when playing from the Tidal app?
They both do not yet support MQA as far as I understand. And when I listened to the M11 I was even wondering if it was not also subject to Android upsampling. The resolution through UAPP and FiiO BTR5 as DAC seemed better. Can someone clarify this?
Also do the iBasso DX220 and DX160 which support MQA really support full resolution with the Tidal app?
